(SR-52) Data Reduction cave survey
09-04-2020, 09:20 PM
(This post was last modified: 09-04-2020 10:25 PM by SlideRule.)
An excerpt from Reducing Cave Survey Data with a Hand Calculator, ASF Newsletter, Autumn, 1977, No. 75, pgs. 2-14
"ABSTRACT The recent advent of a wide range of small electronic calculators greatly facilitates the mathematical reduction of survey data into X, Y and Z co-ordinates for plotting on a grid. presented here are the formulae and methods used for reducing traverse data, closing networks and simple loops, and triangulating inaccessible points. An appendix lists a series of programs for use with the Texas Instruments SR-52 programmable calculator. … APPENDIX SUMMARY OF PROGRAMS FOR THE SR 52 CALCULATOR … The following programs were written specifically for the SR 52, but should be adaptable to other calculators provided they have sufficient memory registers and a long enough program memory (c.f. table 1). As the specific sequence of key steps would tend to vary from one calculator to another, only generalised flow charts are presented here. … THE PROGRAMS … … The TAPE TRAVERSE program … … The NETWORK CLOSURE program … … The SEGMENT or LOOP CLOSURE program … … The TRIANGULATION program … … These programs should be usable in similar or simplified form in a number of other programmable hand calculators. They could also be used (and expanded) with programmable desk-top calculators … …" errata, page 12 ASF News Winter, 1977 No, 76 BEST! SlideRule |
