HP50g simplifing a root
10-09-2020, 05:21 PM (This post was last modified: 10-11-2020 11:32 AM by Albert Chan.)
Post: #21
RE: HP50g simplifing a root
I was being stupid. Why solve cubic equation for a Big Grin
This is the way to get cube roots simplified:
\(\sqrt[3]{A ± \sqrt{R}} = a ± \sqrt{r} \quad ⇒ \quad a = \large\frac{\sqrt[3]{A+\sqrt{R}}
\;+\; \sqrt[3]{A-\sqrt{R}}}{2} \)
Round a to closest halves, get r, and double check if it round-trip back to (A, R)
function simp_cbrt4(A,B,k)  -- simplify cbrt(A + B * sqrt(k))
    local R = B*B*k
    local a = sqrt(abs(R))
    if R<0 then a = (A*A-R)^(1/6) * cos(atan2(a,A)/3)
    else        a = (cbrt(A+a) + cbrt(A-a))/2
    end
    a = a + 0x3p50 - 0x3p50 -- round to halves
    local r = (A/a-a*a)/3
    local b = B/(3*a*a+r)
    if r == b*b*k then return a,b,k end
end
lua> simp_cbrt4(1859814842094, -59687820010, 415)
11589      -145         415
lua> simp_cbrt4(300940299,103940300,101)
99           100          101
lua> simp_cbrt(180, 23, 157)   -- (a,b) can be halves
1.5          0.5          157
lua> simp_cbrt4(-36, 20, -7)    -- work with complex roots too.
3             1             -7
lua> simp_cbrt4(81,30,-3)       -- this is simplest, see comment from previous post.
4.5          0.5          -3
10-10-2020, 03:58 PM
Post: #22
(10-09-2020 05:21 PM)Albert Chan Wrote:  \(\sqrt[3]{A ± \sqrt{R}} = a ± \sqrt{r} \quad ⇒ \quad a = \large\frac{\sqrt[3]{A+\sqrt{R}}
Slightly off topics. I was curious how to calculate a accurately (assumed R > 0)
Since cube root is odd function, we pull out the sign.
a = sign(A)/2 * (³√(|A|+√R) + ³√(|A|-√R))
Last term can be rewritten as ³√(A²-R) / ³√(|A|+√R)
Let c = ³√(A²-R), d = ³√(|A|+√R)², we have:
a = sign(A)/2 * (d + c) / √d
Since both c, d are cube roots, we try identity c³ + d³ = (c + d) (c² - c d + d²)
c³ + d³ = (A² - R) + (A² + R + 2|A|√R) = |2A| * (|A|+√R) = |2A| * d√d
Substitute back in, many terms get cancelled, a = A / (c²/d - c + d) Smile
If ³√(A ± √R) can be simplified, c turns to integer (we had shown this earlier).
In fact, the whole denominator turns to integer = a² + 3r = 4a² - 3c
function calc_a(A,R)
    local c = cbrt(A*A-R)
    local d = cbrt(A*A+R + 2*abs(A)*sqrt(R))
    return A / (c*c/d - c + d)
end
lua> function test_a(A,R)
:           local q = sqrt(R)
:           return calc_a(A,R), (cbrt(A+q) + cbrt(A-q))/2
:      end
lua>
lua> test_a(26, 15^2 * 3)
2      1.9999999999999982
lua> test_a(9416, 4256^2 * 5)
11    11.000000000000005
lua> test_a(300940299,103940300^2 * 101)
99    99.00000000000006
10-10-2020, 04:49 PM
Post: #23
(10-10-2020 03:58 PM)Albert Chan Wrote:  Substitute back in, many terms get cancelled, a = A / (c²/d - c + d) Smile
Proof is trivial:
if ³√(A ± √R) = a ± √r, then
c = ³√(A² - R) = a² - r
d = ³√(|A|+√R)² = (|a|+√r)²
c²/d + d - c = (|a|-√r)² + (|a|+√r)² - c = (2a² + 2r) - (a² - r) = a² + 3r
10-11-2020, 06:28 PM (This post was last modified: 10-12-2020 05:19 AM by Albert Chan.)
Post: #24
(10-09-2020 02:31 PM)Albert Chan Wrote:  Lets rearrange the cubic to match form x³ + 3px - 2q = 0
c³ = A² - R
4*a³ = 3*c*a + A
a³ + 3*(-c/4)*a - 2*(A/8) = 0
→ Cubic discriminant = p³ + q² = (-c/4)³ + (A/8)² = (-c³ + A²) / 64 = R/64
→ If R < 0, we got 3 real roots.
Instead of cubic discriminant, we can show this with more familiar quadratic discriminant.
Let f(x) = 4x³ - 3*c*x - A, so that f(a) = 0
f(x) = 4 * (x-a) * (x² + a*x + (a² - 3*c/4))
Quadratic discriminant = a² - 4*(a² - 3*c/4) = -3*(a² - c) = -3*r
→ if r < 0 (due to R < 0), f got 3 real roots.
We can solve the quadratics, but unnecessary.
If we have 1 solution, where (a ± √r)³ = A ± √R, we can get the other 2.
(a ± √r)³ = ((a ± √r) × w)³ = ((a ± √r) / w)³,     where w = (-1)^(2/3)
Example, simplify ³√(36 + 20i√7)
>>> from mpmath import *
>>> A, B, k = 36, 20, -7
>>> z = A + B*sqrt(k)
>>> q = cbrt(z); print q
(3.79128784747792 + 1.27520055582102j)
>>> c = cbrt(A*A-B*B*k); print c
16.0
q looks hopeless to simplify, but c is integer, thus possible.
Perhaps the "nice" root is not the principle root ?
>>> w = exp(2j/3*pi)
>>> print q*w, q/w
(-3.0 + 2.64575131106459j)      (-0.791287847477919 - 3.92095186688561j)
>>> a = -3
>>> f = lambda x: 4*x**3 - 3*c*x - A
>>> print f(a)
0.0
>>> print a, (A/a - a*a)/3
-3       -7.0
We have ³√(36 + 20i√7) = (-3 + i√7) / (-1)^(2/3)
However, converted to form a ± √r, expression look messier than original ³√(A + √R) Sad
10-12-2020, 03:17 AM (This post was last modified: 10-13-2020 12:08 PM by Albert Chan.)
Post: #25
(10-11-2020 06:28 PM)Albert Chan Wrote:  Example, simplify ³√(36 + 20i√7)
16.0
Here is a novel way to solve for r instead, then get a.
(Note: b can be halves, just like a)
R/r = (B/b)² = (3c + 4r)² = integer, where r = b²k
For this case, we hit the jackpot. If b=±1, 3c+4r = 3c+4k = B Smile
r = k = -7
a = A / (c+4r) = 36/ (16-28) = -3
3*arg(a±√r) = 3*atan2(±√7, -3) ≈ ±2.3098 pi
We need to match above angle to arg(A+√R), which is on the first quadrant.
+2.3098 pi - 2 pi = 0.3098 pi matches.
This is just for fun. No need to solve the cubics.
Directly calculate ³√(A+√R) (previous post) is preferred.
Comment: Solving for b instead, we can take square root of both side
B/b = 3c + 4r = 3c + 4kb² = integer
This removed the ambiguity of b = ±1 to b = B/(3c + 4kb²) = 1
Above example need to match angles anyway, so I skipped this.
10-12-2020, 08:49 PM
Post: #26
Hello Albert,
I'm really stunnig about your investigations in this topic. Wow, in future I should be more careful in arising such topics! ;-)
10-12-2020, 10:54 PM
Post: #27
c³ = A² - R
4*a³ = 3*c*a + A
see https://proofwiki.org/wiki/Cardano%27s_Formula
I just realized my direct calculation for a is really using Cardano's formula Big Grin
a = ³√(q + √Δ) + ³√(q - √Δ)
   = ³√((A/8) + √(R/64)) + ³√((A/8) - √(R/64))
   = (³√(A+√R) + ³√(A-√R)) / 2
10-12-2020, 11:45 PM (This post was last modified: 10-13-2020 12:02 AM by CMarangon.)
Post: #28
Well, I conclude that HP50 does not have the formulas below, into memory.
Maybe, it can be included, in next ROM update.
Formula:
(A ± B⋅√k)^(1/3) = a ± b⋅√k
See also post #22, from Albert Chan, above.
Carlos (BR)
(10-09-2020 12:20 AM)Albert Chan Wrote:  Unfortunately, our divisors based cube root simplify routines were flawed !
Real rational root for a is a divisor of n, *but* possibly divided by 4 ...
Another problem is we had assumed there is only 1 real root for a.
c³ = A² - R
4*a³ = 3*c*a + A
Quote:XCas> find_cbrt(81,30,-3)       → \(\frac{9}{2} + \frac{i}{2}\cdot\sqrt{3}\)
XCas> find_all_a(A,R) := solve(surd(A*A-R,3) = a*a - (A/a-a*a)/3 , a)
XCas> find_all_a(81, 30^2 * -3)       → [-3, -3/2, 9/2]
XCas> simplify( [-3+2i*sqrt(3), -3/2-5i/2*sqrt(3), 9/2+i/2*sqrt(3)] .^ 3)
\(\qquad\quad [81 + 30i\sqrt3\;,\; 81 + 30i\sqrt3\;,\; 81 + 30i\sqrt3 \)
If we consider integer as simplest, then \(\sqrt[3]{81 + 30i\sqrt3} = -3+2i\sqrt3\)
Comment: I was wrong on above example.
x³ = y does not imply ³√y = x. We need to consider branch-cut
In other words, simplified form should match numerical evaluated values.
>>> (81 + 30j * 3**0.5) ** (1/3)
(4.5+0.86602540378443837j)
Carlos - Brazil
Time Zone: GMT -3
http://area48.com
10-13-2020, 06:30 AM
Post: #29
Hello Albert,
This was the origin of my thoughts for simplyfing, because I construct examples to test cardanos formular i keyed in my HP50g and I got that kind of "garbage" for simple solutions i. e. 1 minus root of two. So my question arises, why my calc cannot simplify this...the rest is history in nearly 30 posts...
10-13-2020, 06:36 AM
Post: #30
Hello CMaragon,
don't wait for a rom update, I'm feared you don't live long enough, because the HP50g is no longer produced and so the last rom version is 2.15. It's a pity, but for HP calc department is "prime time".
10-13-2020, 06:46 AM
Post: #31
(10-12-2020 11:45 PM)CMarangon Wrote:  Well, I conclude that HP50 does not have the formulas below, into memory.
Sadly the 50g was discontinued 5 years ago. There will be no ROM update Sad
There are only 10 types of people in this world. Those who understand binary and those who don't.
10-24-2020, 02:19 PM
Post: #32
(10-11-2020 06:28 PM)Albert Chan Wrote:  We have ³√(36 + 20i√7) = (-3 + i√7) / (-1)^(2/3)
Mathematica gives many "simplifed" forms, here are 2 of them.
(-3+i√7) * (-1-i√3)/2 = (√21+3)/2 + i/2*(3√3-√7) = (√21+3)/2 + i/2*√(34-6√21)
I was curious, given √(34-6√21), how to "simplify" to (3√3-√7) ?
We can use the same trick (if LHS is real, for both ±)
\( \sqrt{A ± B\sqrt{c d}} = a\sqrt{c} \,±\, b\sqrt{d} \quad ⇒ \quad
a\sqrt{c} = \large\frac{\sqrt{A+B\sqrt{c d}}\;+\;\sqrt{A-B\sqrt{c d}}}{2} \)
lua> A, B, k = 34, -6, 21
lua> C = B * sqrt(k)
lua> mean = (sqrt(A+C) + sqrt(A-C))/2
lua> mean^2
27
27 = 3*3*3 = a*a*c. We try a=c=3, d=7, so just solve for b:
(3√3 + b√7)² = (27+7b²) + 6b√21 = 34 - 6√21
We have b = -1, thus √(34 - 6√21) = 3√3 - √7
It is nice that XCas do this automatically Smile
XCas> simplify(√(34-6*√(21)))      → 3√3 - √7
