Dew and Bubble Point 2.0.
10-27-2020, 10:45 PM
Allows you to calculate the Dew Point (temperature, pressure and composition
of the first drop created in a gas mixture) and Bubble point (temperature, pressure and composition of the first bubble created in a liquid) of a mixture of "N" nº of components. To make the calculation, the Secant Method is used to find the roots. You can also choose between Antoine or McWilliams (if it's a hydrocarbons' mixture) for equilibrium parameters calculations. ***Version 2.0 A DATABASE OF ANTOINE & MCWILLIAMS COEFFICIENTS HAVE BEEN ADDED AND IS INTENDED TO OPTIMIZE THE USE OF THE PROGRAM. Antoine Database --> ºC , bar & using log() McWilliams Database --> ºR , psia ***Version 1.1 THIS VERSION PROVIDES AN IMPORTANT BUG FIXED WHICH AFFECTED THE CORRECT PERFORMANCE OF THE McWILLIAMS EQUATION. |
