Python survey 2020
10-30-2020, 02:25 PM
(This post was last modified: 10-30-2020 09:07 PM by compsystems.)
Python survey 2020
Hello
What does Python need to be a super language? If you want you can share your ideas in this forum and in the following survey. https://surveys.jetbrains.com/s3/c8-pyth...urvey-2020 1: A type of symbolic object for algebraic manipulation CAS 2: ... There is also a draw with 100 winners (surprise prize) to whoever completes the form |
10-30-2020, 08:36 PM
RE: Python survey 2020
Is it well translated in multiple languages, or did you have to answer in French?
![]() It is a high quality survey. Thibault - not collector but in love with the few HP models I own - Also musician : http://walruspark.co |
11-01-2020, 05:59 AM
I know they won't add it, but Python could use a DO-WHILE or REPEAT-UNTIL or equivalent loop structure where the condition is evaluated at the end of the loop. I don't know that I've ever used a language without such a loop construct. I know you can use a "while True:" and a "break" but that looks so kludgy.
(On the plus side, I don't know that I've seen another language with the while-else construction that Python has. That's kind of cool.) |
11-01-2020, 10:51 AM
(11-01-2020 05:59 AM)Wes Loewer Wrote: I know they won't add it, but Python could use a DO-WHILE or REPEAT-UNTIL ... Assumed Python do have repeat/until: repeat: ... # some code if condition: continue bad = 0 ... # code that might turned "bad" until bad if condition is true, it will jump to line "until bad". However, bad is a local variable, not existed before condition test. (Or worse, bad existed outside repeat/until loop, and used for until ...) You could solve it by moving up bad=0 before the condition test. But, that would be messy to document repeat/until usage. Static typed language does not have this problem. Code won't compile. |
11-01-2020, 02:25 PM
A native BCD decimal data type would be a big step in the right direction. C# handles it very well.
11-01-2020, 04:45 PM
(This post was last modified: 11-01-2020 04:53 PM by toml_12953.)
(11-01-2020 05:59 AM)Wes Loewer Wrote: I know they won't add it, but Python could use a DO-WHILE or REPEAT-UNTIL or equivalent loop structure where the condition is evaluated at the end of the loop. I don't know that I've ever used a language without such a loop construct. I know you can use a "while True:" and a "break" but that looks so kludgy. You can do this: Code: while True: That's the equivalent of Code: DO I know you think it looks kludgy as did I, coming from a BASIC background, but if you use Python for a while you get used to it. Since Python programmers think in terms of While True, there's no incentive to change it. Tom L Cui bono? |
