DM41X Time Correction
10-31-2020, 08:18 PM
In the DM41X manual chapter 3.8 (RTC Correction) describes a method to correct the internal accuracy of the clock. On the other hand the HP-41CX (or Time Module) knows the function "CORRECT" for this purpose. Can the original "CORRECT" still be used for correction, or is it necessary to use the method described in chapter 3.8? Thanks and Greetings!
10-31-2020, 09:32 PM
RE: DM41X Time Correction
The timer hardware is totally different in the DM41X so the CORRECT instruction doesn't work. Remember, the DM41X is an emulator that is running the original 41CX ROM, so executing CORRECT is going to attempt to address hardware that isn't there.
There are only 10 types of people in this world. Those who understand binary and those who don't.
10-31-2020, 09:36 PM
(10-31-2020 09:32 PM)grsbanks Wrote:  The timer hardware is totally different in the DM41X so the CORRECT instruction doesn't work. Remember, the DM41X is an emulator that is running the original 41CX ROM, so executing CORRECT is going to attempt to address hardware that isn't there.
Ok, thanks!
