HP Prime question (how to plot pairs of data)
11-02-2020, 04:34 AM
I am using the HP Prime (Lite) on my iPad as a way to check out the calculator before buying it.
I want to do a very simple operation which is to connect a bunch of dots.
These are defined as pairs, e.g. (0,0), (120, 200), (240, 400), (247, 410)
I do not want to do a "linear fit" or to do a scatter plot. I want a line that joins these dots.
Any help?
Thanks
**vp
11-02-2020, 03:46 PM
RE: HP Prime question (how to plot pairs of data)
Have you tried the geometry app:
-road
11-03-2020, 03:57 AM
(11-02-2020 03:46 PM)roadrunner Wrote:  Have you tried the geometry app:
You mean define the data pairs as points and then draw line segments to join them?
This is rather tedious esp. if you have lots of points.
Is there a faster way to do it?
Thanks
**vp
11-03-2020, 05:11 AM
Put data in Stat2Var app, in plot stup page 2 mark "connect" and it will just join your lines.
TW
11-03-2020, 08:28 AM
Works like a charm
thanks Tim
**vp
