HP-65 1602A01827 restore and an idea for the back label
11-08-2020, 11:24 PM (This post was last modified: 11-08-2020 11:29 PM by albertofenini.)
Hi everyone,
hope everyone is doing well and in good health !
Since we are in a regional lockdown we took out our tools and got back to work.
This was a simple restoration, but we have worked out an idea that could be of interest
for the applying the back table as smooth as possible.
Using an old plastic mat we have cut a piece of it exactly the size of the back label.
It must be of the exact size, it will be used to apply the necessary pressure once the
glue has been sprayed and it will be used to keep under pressure the label while the glue dries out.
Attached is a link with some picture, we will post the final result tomorrow since the glue must dry for 24 hours (it's a 3M model)
As a final note, we had restored the card reader wheel with silicone tubing but it didn't work so we reversed to the o'ring solution
[Edit] Please note that since the Apple shared albums are posted with the most recent picture first,
the picture with the back label attached was taken before the restoration and before the label was removed
Edoardo & Alberto
11-09-2020, 08:51 AM
RE: HP-65 1602A01827 restore and an idea for the back label
Hello and thanks for sharing the photos and the video. Does the video show the original back label or is it a replica?
I need a back label for my HP-55, because I received the device without a back label.
Do you know of a process for making a replacement back label?
Any hint will be very much appreciated.
Best regards
Karl
11-09-2020, 11:43 AM
Hello
the one in the video is the original one, which has been removed in order to open the unit and has been glued back, later today I will show the result ...
As far as from replica labels you may try on TAS, lookout for this seller waterhosko, he makes this for the HP67 so he ma be doing other as well, or inquiry the forum here ...
(11-09-2020 08:51 AM)Karl-Ludwig Butte Wrote:  Hello and thanks for sharing the photos and the video. Does the video show the original back label or is it a replica?
Best regards
Karl
Edoardo & Alberto
11-09-2020, 06:24 PM
At the following link you can see the result after 24 hours
It must be said that the original label was in very good condition
Take care !!!
Back label the final result ...
Edoardo & Alberto
11-09-2020, 08:57 PM (This post was last modified: 11-09-2020 08:58 PM by aurelio.)
Great job Alberto, really great
A nice photo report also of the process
Bravissimo!!
I'll try one day (if I'll find the pasta machine, which takes rest somewhere in a friend of mine's backyard) in restoring the label of one of the 67's which has problem in the upper corners: I'm the guilty while attempting to fix the card reader, time ago ...
11-09-2020, 09:58 PM
We have uploaded a few more pictures
With the described method the pressure was applied mostly on the outside of the shell
By putting a couple of plastic water bottle caps inside the shell we have been able to apply a quite homogeneous pressure also from the inside
The result is shown in the last uploaded pictures and we think is better than before
We will try it with a less well preserved label and see hot it turns out
Take care !!!
Edoardo & Alberto
11-09-2020, 11:08 PM
(11-09-2020 09:58 PM)albertofenini Wrote:  We have uploaded a few more pictures
[omissis]
Take care !!!
Sorry, I Forgot Edoardo...
11-10-2020, 08:34 AM
Don't worry I'll tell him, but thanks !!
[omissis]
Take care !!!
Edoardo & Alberto
11-10-2020, 10:16 AM
(11-09-2020 11:43 AM)albertofenini Wrote:  Hello
Best regards
Karl
thanks Edoardo & Alberto for the info. I contacted waterhosko but unfortunately he doesn't have any 55-Labels. Perhaps some day, somehow there will be a solution.
Best rfegards
Karl
