LIB maker for HP50?
11-11-2020, 01:53 AM
LIB maker for HP50?
What is a good LIB maker & installer, for HP50? Carlos - Brazil Time Zone: GMT -3 http://area48.com |
11-11-2020, 05:39 AM
RE: LIB maker for HP50?
FWIW, I use the built-in CRLIB command. It's documented in the 50g AUR manual, Chapter 6, in the section entitled "CRLIB -- Create Library Command" (pages 6-9 through 6-10).
<0|ɸ|0> -Joe- |
11-11-2020, 08:14 PM
I already have read this post from you, at HP.com. Thank you! (11-11-2020 05:39 AM)Joe Horn Wrote: FWIW, I use the built-in CRLIB command. It's documented in the 50g AUR manual, Chapter 6, in the section entitled "CRLIB -- Create Library Command" (pages 6-9 through 6-10). Carlos - Brazil Time Zone: GMT -3 http://area48.com |
11-18-2020, 08:47 AM
Maybe I can use L.I.C? [APPS] [14 L.I.C] ![]() Carlos - Brazil Time Zone: GMT -3 http://area48.com |
11-18-2020, 01:52 PM
(11-18-2020 08:47 AM)CMarangon Wrote: Hello! L.I.C. doesn't create libraries; it creates library installers. Furthermore, L.I.C. is not a built-in feature of the HP 50g; it only appears in the APPS list of the machines in which L.I.C. was installed. See the README.TXT file that comes with it: https://www.hpcalc.org/details/4761 <0|ɸ|0> -Joe- |
