Update of Emu71/Win to v1.13
11-17-2020, 08:20 PM
Emu71/Win v1.13 is a maintenance update available at https://hp.giesselink.com.
The prior version v1.12 fixed a performance issue with the BASIC GOTO command. This fix had a side effect on some PC's resulting in duplicate keystrokes from the PC keyboard. v1.13 should solve this issue. v1.13 does not support ROM beep patches any more. The prior version generated a warning when detecting a ROM beep patch, this actual version stops with an error. |
