HP-48GX ROM P
11-24-2020, 11:52 PM
HP-48GX ROM P
Hi, I have seen a HP48GX ROM Version P with something like P-Cop...
See the attached picture, is this ROM version normal? I have never seen that before. Thanks |
11-25-2020, 01:52 AM
RE: HP-48GX ROM P
It would be easier to reply if the picture actually was attached...
--Bob Prosperi |
11-25-2020, 03:56 AM
RE: HP-48GX ROM P
HP 48GXs with ROM-P are rare animals, but yes they existed.
https://www.hpmuseum.org/cgi-sys/cgiwrap...i?read=991 Adrian Coto |
11-25-2020, 07:18 AM
RE: HP-48GX ROM P
(11-25-2020 01:52 AM)rprosperi Wrote: It would be easier to reply if the picture actually was attached... Hi, sorry, I attached it but I do not know why it has not worked, trying again... |
11-25-2020, 07:20 AM
RE: HP-48GX ROM P
(11-25-2020 03:56 AM)acoto Wrote: HP 48GXs with ROM-P are rare animals, but yes they existed. Yeah, but the thing is that it's PCop... version, not P, as I do not have it I cannot edit to read the rest of the string. |
11-25-2020, 09:09 AM
(This post was last modified: 11-25-2020 09:41 AM by Giuseppe Donnini.)
RE: HP-48GX ROM P
No mystery here:
The VERSION command returns the following two string objects to stack levels 2 and 1, respectively: 2: "Version HP48-X" 1: "Copyright HP 1993" where X represents the actual ROM revision number. Now, you only have to inadvertently hit the [+] key and both strings end up being concatenated, which looks like this: 1: "Version HP48-XCop… (In the case of string objects, the system decompiler responsible for stack objects does not add line feeds even if you are in multi-line mode, which is the default setting (system flag -52 clear). So the result will always be one single line, if necessary truncated to 19 characters, including the opening double-quote delimiter and the closing ellipsis.) |
11-25-2020, 04:07 PM
(This post was last modified: 11-25-2020 04:09 PM by MD80_ESP.)
RE: HP-48GX ROM P
(11-25-2020 09:09 AM)Giuseppe Donnini Wrote: No mystery here: It's not my calculator or picture, I got it from a seller (I have 48SX and 50G and want a 48GX ROM R), and I should have noticed that (banging head against table)...my stack abilities are a bit rusty :-( Thanks. |
06-23-2023, 07:14 PM
RE: HP-48GX ROM P
Please add my calculator rom to the list, since this will make it the first GX on the list. The date sequence is unusual as rom version M was still being installed in 48G's at the time, according to the list.
48gx P 3342S10281 Singapore 1993 42 I can email photos or video for verification, let me know where to send it. A couple years ago I had a guy replace the screen with one from a 38g and all is very nice on it now. On average, the clock speed is 3748864. 35 - 45 - 65 - 48sx/gx - xpander - dm42 |
