Linear Exponential Combination Fit
11-30-2020, 03:45 PM
http://edspi31415.blogspot.com/2020/11/h...ation.html
The program LINEXPREG attempts to fit bivariate data to the curve: y = a + b * x + c * e^x The LSQ (least square) function is used. The output is a list of three matrices: * A matrix of coefficients: [ [ a ] [ b ] [ c ] ] * A matrix of y values entered * A matrix of predicted y values HP Prime Program LINEXPREG Code: EXPORT LINEXPREG(lx,ly) Example x list: {0, 1, 2, 3, 4, 5} y list: {2, 7, 13, 18, 26, 34} LINEXPREG({0, 1, 2, 3, 4, 5},{2, 7, 13, 18, 26, 34}) Results: {coefficients, y values, predicted y values} coefficients: [ [ 1.74935499143 ] [ 5.39455446221 ] [ 3.66584105034E-2 ] ] y values: [ [ 2 ] [ 7 ] [ 13 ] [ 18 ] [ 26 ] [ 34 ] ] predicted y values: [ [ 1.78601340193 ] [ 7.24355734477 ] [ 12.8093349675 ] [ 18.6693222357 ] [ 25.3290542368 ] [ 34.1627178129 ] ] Equation: y = 1.74935499143 + 5.39455446221 * x + 3.66584105034E-2 * e^x |
12-03-2020, 01:39 AM
(This post was last modified: 08-21-2023 03:42 PM by Albert Chan.)
RE: Linear Exponential Combination Fit
Hi, Eddie
Thanks for the post. I did not know HP Prime had LSQ function. It might be simpler not to create a flatten list (with CONCAT), then reconstruct the matrix. We could build the matrix, functional style: CAS> lx := range(6) CAS> ly := [2, 7, 13, 18, 26, 34] CAS> fit := LSQ(transpose([0*lx .+ 1., lx, e^lx]), ly) [[1.74935499144],[5.39455446221],[3.66584105036e−2]] CAS> [[1,x,e^x]] * fit [[ 3.66584105036E−2*e^x + 5.39455446221*x + 1.74935499144 ]] Comment: Aug 21, 2023 ".+" is supposed to apply sum element-by-element. However, XCas (lx-lx) .+ 1. does not populate matrix with all one's, (0*lx .+ 1.) does. To bypass the bug, above is adjusted so that both CAS, XCAS produce same results. Also, if we only need polynomial regression, there is a shortcut polynomial_regression(lx, ly, degree_needed) |
User(s) browsing this thread:
