Missing one root
12-13-2020, 01:07 AM
Missing one root
I'm going over some simple math problems on both my HP50G and my Prime.
When I try to solve the very simple equation
(x-3)^(2/3) = 4
The HP50G correctly provides 11 and -5 as answers within a list
However the Prime only finds 11 as root, also within a list.
What gives?
Thanks for reading.
12-13-2020, 01:38 AM
RE: Missing one root
Try using surd for the 1/3 power.
Cas> solve((surd(x-3,3)^2) = 4,x)      → {-5,11}
12-13-2020, 02:52 AM
(12-13-2020 01:38 AM)Albert Chan Wrote:  Try using surd for the 1/3 power.
Thanks!!! It worked.
However, I still would like to know what's behind the difference between how the 50G and the how the Prime find the roots.
12-13-2020, 03:45 AM (This post was last modified: 12-13-2020 03:56 AM by victorvbc.)
(12-13-2020 02:52 AM)rrpalma Wrote:  Thanks!!! It worked.
By using the fractional exponent "1/3" the Prime returns the principal cube root, which in this case will be a complex number for any x<3. Whereas using surd or NTHROOT it returns the real-valued root instead, allowing for a zero at x=-5 in the equation (x-3)^(2/3)-4=0.
Edit: Wolfram Alpha for reference: https://www.wolframalpha.com/input/?i=%2...3%29-4%3D0
If you want to assume the real-valued root on the Prime, always use the root template key, nthroot, or equivalent.
12-13-2020, 04:33 AM
Thanks. Very much appreciated. I tried it both with NTHROOT and the template, and it worked. I'm still confused on why HP50G directly provides the real-valued root(s) whereas the Prime doesn't. I guess that's the way it is, and that's it. Or, how do I force then the HP50G to provide only the principal root?
12-16-2020, 02:12 AM (This post was last modified: 12-16-2020 02:20 AM by cdmackay.)
(12-13-2020 04:33 AM)rrpalma Wrote:  Or, how do I force then the HP50G to provide only the principal root?
I had thought that setting system flag -1 "principal value" might do it; but no, not with SOLVE.
Whereas if you use ISOL (isolate), it does honour the flag, but shows X=-5 only Smile
Cambridge, UK
41CL/DM41X 12/15C/16C DM15/16 17B/II/II+ 28S 42S/DM42 32SII 48GX 50g 35s WP34S PrimeG2 WP43S/pilot
Casio, Rockwell 18R
12-16-2020, 03:37 AM
Thanks!! That's really odd :-)
