Can Prime do double or triple Integrals
01-05-2021, 12:45 AM
(This post was last modified: 01-05-2021 12:56 AM by tom234.)
Can Prime do double or triple integrals like this?
Just be clear I just need a yes or no. I haven't seen any videos on this approach on HP Prime. |
01-05-2021, 02:50 AM
RE: Can Prime do double or triple Integrals
Yes! Symbolically in CAS, decimal approximation in HOME.
01-05-2021, 05:11 AM
Just for fun, I nested 10 integrals and the Prime handled it just fine!
Cemetech | YouTube |
01-05-2021, 06:34 AM
Yes, HP PRIME can solve this kind of integrals.
01-05-2021, 05:36 PM
But the Prime seems to have problems in some cases where other calculators are doing fine. See the thread https://www.hpmuseum.org/forum/thread-15...#pid132535
I tried it again (because it could be that there was an update in between) but the problems are still there. To answer the question at the beginning of the thread: To me it seems that in principal it is possible but it is not very stable. Best |
01-05-2021, 07:42 PM
RE: Can Prime do double or triple Integrals | |||
01-05-2021, 08:11 PM
01-06-2021, 06:22 AM
Good morning
if you look closely at the figure you realize that "d" are present. Or maybe I didn't understand the question? Best wishes, Roberto. |
01-08-2021, 10:49 AM
(01-06-2021 06:22 AM)robmio Wrote: Good morning yes in the second integral. However, if I use the template it requires using ?d? as it is displayed in the example from you for the first integral. how are you getting the first integral without the dxd entries? |
01-08-2021, 04:44 PM
(01-08-2021 10:49 AM)tom234 Wrote:(01-06-2021 06:22 AM)robmio Wrote: Good morning Okay just did the template in the second template inside of the box of the first template it works. |
