IFT-structure
01-05-2021, 10:19 AM
IFT-structure
About my previus post to which I couldn't add a reply, here is a logical explanation.
IFT looks for the last but one element before itself (true/1 or not true/0) to execute the instruction just before itself.
But as DROP-command has cleared, by definition, the last argument in the stack (at level 1), a problem arises logically, so that John's Keith's suggestion is not valid in that case.
Here I copied my original thread:
About the use of IFT
suggested by John Keith
Try and run that program:
«1000 6 5 > 1 == DROP IFT
Well, it seems that it does not work with the
"object" command DROP.
But, of course
«1000 6 5 > 1 == IF THEN DROP END
works fine with DROP
and normal IF... THEN... End.
IFT will work fine, however, with "positive"
instead of command DROP
«1000 6 5 > 1 == "POSITIVE" IFT
Gil
