How to delete a program on the DM42/Free42
01-07-2021, 01:43 PM
Can someone tell me how I can delete a program on the DM42/Free42 ?
01-07-2021, 03:15 PM
RE: How to delete a program on the DM42/Free42
shift-CLEAR CLP
Cheers, Werner
41CV†,42S,48GX,49G,DM42,DM41X,17BII,15CE,DM15L,12C,16CE
01-07-2021, 04:04 PM
Get yourself a copy (electronic or physical, up to you) of the HP-42S manual. This is covered in it.
There are only 10 types of people in this world. Those who understand binary and those who don't.
01-07-2021, 06:43 PM
https://thomasokken.com/free42/#doc
01-07-2021, 06:55 PM
(01-07-2021 04:04 PM)grsbanks Wrote:  Get yourself a copy (electronic or physical, up to you) of the HP-42S manual. This is covered in it.
Yes I tried to find it but I just don’t know one what page to look
01-07-2021, 07:15 PM
(01-07-2021 03:15 PM)Werner Wrote:  shift-CLEAR CLP
Cheers, Werner
Thanks
02-26-2023, 02:05 AM
how do you unassign it from the custom menu and unload it? i can do it, but i'd have to clear the state and populate the custom menu all over again. tks, /guy
We were somewhere around the Withywindle on the edge of the Old Forest when the drugs began to take hold. ~Hunter S. Tolkien
02-26-2023, 02:46 AM
(02-26-2023 02:05 AM)gteague Wrote:  how do you unassign it from the custom menu and unload it? i can do it, but i'd have to clear the state and populate the custom menu all over again. tks, /guy
To un-assign a program from an assigned CST key:
1. Press [shift] [CONF] to access the CONF mode
2. Press the key (A..P) that you want to un-assign (which has the program name you want to remove)
3. Press [<-] to erase all the letters in the program name until it's clear
4. Press [R/S] to save the change
5. Press [<-] to exit the CONF mode
Once unassigned, you can then use CLP to delete the program (if that is what you want).
02-26-2023, 02:49 AM (This post was last modified: 02-26-2023 02:59 AM by gteague.)
thank you very much! i appreciate it. when i got my dm42 i overloaded myself trying to learn all the things i needed and i sort of burned out and took a year off it to recover and am now making another run at it. Smile
at least i found the new persistent custom menu capability waiting for me and that had nearly made it a brand new calculator. still haven't found where it saves the custom menu items so that i could restore them when i have to restore a state--any idea why the save state doesn't save the custom menu? tks, /guy
