Quick question: how to do Volume formula on the solver
01-09-2021, 04:58 AM (This post was last modified: 01-09-2021 04:59 AM by fs5qc.)
Can you tell me how I can calculate a variable of a volume on the prime if I do V=W*L*H than I input on W 2.5 and 5.5 on H I got 0 on V
Attached File(s) Thumbnail(s)
01-09-2021, 06:53 AM
RE: Quick question: how to do Volume formula on the solver
Good morning.
From the attached figure I deduce that W = 2.5, L = 5.5, H = 0. So V = 2.5 * 5.5 * 0 = 0. Where is the problem?
01-09-2021, 11:55 AM (This post was last modified: 01-09-2021 11:56 AM by fs5qc.)
(01-09-2021 06:53 AM)robmio Wrote:  Good morning.
If I do the sa me with a hp 42S (with a program) the calculator would solve for the variable that got no number or 0
I want to do the same on the prime
01-09-2021, 12:29 PM (This post was last modified: 01-09-2021 12:30 PM by SammysHP.)
But if the volume is zero, one of the dimensions must be zero. Or the other way around: If one dimension is zero, the volume will be zero as well. What do you expect?!
01-09-2021, 12:48 PM (This post was last modified: 01-09-2021 12:49 PM by fs5qc.)
Can you explain why is working with the 42S but not the prime ?
(01-09-2021 12:29 PM)SammysHP Wrote:  But if the volume is zero, one of the dimensions must be zero. Or the other way around: If one dimension is zero, the volume will be zero as well. What do you expect?!
01-09-2021, 12:50 PM
On the 42S I got L=7.272727272727272727272727272727273 But not on the prime
(01-09-2021 12:48 PM)fs5qc Wrote:  Can you explain why is working with the 42S but not the prime ?
01-09-2021, 01:04 PM
I saw that you put V = 100, W = 2.5 and L = 5.5 --> Look at my attachment.
01-09-2021, 01:06 PM
Yes but what I am doing wrong??? You is working fine me not
(01-09-2021 01:04 PM)robmio Wrote:  I saw that you put V = 100, W = 2.5 and L = 5.5 --> Look at my attachment.
01-09-2021, 01:10 PM (This post was last modified: 01-09-2021 01:12 PM by fs5qc.)
Oh I got It I need to select H form my mistake
Thanks for your help
(01-09-2021 01:06 PM)fs5qc Wrote:  Yes but what I am doing wrong??? You is working fine me not
01-09-2021, 01:12 PM
Put in E1: V = W * H * L; now press the "Num" key. Put in V: 100; put in W: 2.5; put in L: 5.5; now go with the cursor on the rectangle to the right of H: and press "Solve".
01-09-2021, 01:14 PM
Yes I got it thanks for your help Smile
(01-09-2021 01:12 PM)robmio Wrote:  Put in E1: V = W * H * L; now press the "Num" key. Put in V: 100; put in W: 2.5; put in L: 5.5; now go with the cursor on the rectangle to the right of H: and press "Solve".
