Answer as CM when not wanted
01-21-2021, 01:13 AM
My Prime and the Prime app is giving me a answer in CM when I don’t asked for a conversion.
What I can do to make it showing normal unit ?
Attached File(s) Thumbnail(s)
01-21-2021, 06:27 AM
RE: Answer as CM when not wanted
It seems that your x variable contains the value 99.502_cm.
You need to do: purge(x) to unassign x and make it symbolic.
01-21-2021, 09:48 AM
Ok is working juste strange
(01-21-2021 06:27 AM)Didier Lachieze Wrote:  It seems that your x variable contains the value 99.502_cm.
