HP-12C Platinum and [CLx]
02-04-2021, 06:31 AM (This post was last modified: 02-04-2021 12:09 PM by Gamo.)
Is the HP-12C Platinum when press the [CLx] key suppose to disable stack lift or
orther word the stack is not lift ??
Example keystroks problem:
For HP-12C used FIX 2
8 [ENTER] [ENTER] 10 [△%] display 25.00
[CLx] [LSTx] display 10.00 [X<>Y] display 8.00 [△%] display -20.00
For HP-12C Platinum used RPN mode FIX 2
[CLx] [LSTx] display 10.00 [X<>Y] display 0.00 (At this step display should be 8.00)
I saw in the HP-12C Platinum manual state that the [LSTx] will not lift stack if the [CLx] was the last key presses.
This can be read on page 230 Appendix A: RPN and the Stack
Gamo
