TI-59 module listings?
02-05-2021, 03:46 PM
Has anybody extracted and gathered code listings from the various solid-state modules for the TI-59/58? I'm curious to look at some of the algorithms, compare them with HP implementations, maybe key in some of the shorter ones on my 58C, etc., but I only have the Master Library at my disposal.
And if the listings haven't been collected anywhere, is there an emulator that makes it particularly easy to extract them? |
02-05-2021, 06:54 PM
RE: TI-59 module listings?
Master library can be found here:
RSKEY page containing Master Library Survival Guide Download the PDF by Fred Fish on this page - name is in the link. Gene |
02-05-2021, 07:31 PM
(02-05-2021 06:54 PM)Gene Wrote: Master library can be found here: Nice, hadn't spotted that hiding in there. Is there anything similar for the other modules? |
02-05-2021, 07:43 PM
On the TI58C emulator site from Pierre Houbert you can find the module files as well as the tieditor utility to extract the listings.
02-05-2021, 09:33 PM
Excellent. We need to get those listings posted someplace.
As to a survival guide for anything else... no, sorry. The TI PPC Notes has a lot of commentary about finding code sequences in roms to enable entry into fast mode (which was eventually obsoleted by using a STF IND instruction at the end of a partition... but I digress). Anyway... they did have a lot to say about the Math / Utilities library. Probably the best TI ever made. |
02-05-2021, 10:04 PM
(02-05-2021 07:43 PM)Didier Lachieze Wrote: On the TI58C emulator site from Pierre Houbert you can find the module files as well as the tieditor utility to extract the listings. Ah ha, that did the trick. Thanks! |
02-07-2021, 12:55 PM
Yes, On my TI58C website ti58c.phweb.me you will find a lot of module sources !
http://ti58c.phweb.me http://clones.phweb.me http://www.instagram.com/ti58c "No! Do or Do not. There is no try!" [Master Yoda] |
02-07-2021, 01:37 PM
(02-07-2021 12:55 PM)Pierre Wrote: Yes, On my TI58C website ti58c.phweb.me you will find a lot of module sources ! When I attempt to go to your site, my security s/w stops, prevents access and warns that "This is a known dangerous webpage." Is it possible your site was hacked and is distributing malware?? --Bob Prosperi |
02-07-2021, 02:01 PM
RE: TI-59 module listings? | |||
02-07-2021, 02:28 PM
I get no warning, either.
Greetings, Massimo -+×÷ ↔ left is right and right is wrong |
(This post was last modified: 02-07-2021 02:28 PM by Sylvain Cote.)
(02-07-2021 02:01 PM)Maximilian Hohmann Wrote:No warning here.(02-07-2021 01:37 PM)rprosperi Wrote: When I attempt to go to your site, my security s/w stops, prevents access and warns that "This is a known dangerous webpage."I get no warning with my settings. Maybe this is simply because it is not a secure "https" site? System is: macOS Catalina 10.15.7, with system firewall active and LittleSnitch Application firewall active Tested with Safari 14.0.2 and Firefox 85.0.1 but not tested on Chrome (I no longer use anything based on Chrome) edit: typo |
02-07-2021, 04:14 PM
(This post was last modified: 02-07-2021 07:27 PM by Garth Wilson.)
No problem here either. I'm using Firefox 85.0 under Ubuntu 18.04.5 Linux.
Thanks Pierre for that resource. Edit: I see I already had it bookmarked. It does not have the module listings though that the OP was asking about. http://WilsonMinesCo.com (Lots of HP-41 links at the bottom of the links page, at http://wilsonminesco.com/links.html#hp41 ) |
02-07-2021, 05:12 PM
Strange...
I can access many other non https:// sites with no warning, so it's not just that. It seems the site was reported to Norton (somehow) as troublesome, so it's blacklisted. Good to know it seems safe, thanks for the additional comments. --Bob Prosperi |
02-07-2021, 07:21 PM
(02-07-2021 05:12 PM)rprosperi Wrote: Strange... Symantec... Greetings, Massimo -+×÷ ↔ left is right and right is wrong |
02-07-2021, 09:24 PM
(02-07-2021 07:21 PM)Massimo Gnerucci Wrote: Symantec... Not anymore.... alas, the spun-off company is now 'Norton Lifelock', and they make Symantec look wholesome... but the product is still great, at least for the time being. --Bob Prosperi |
02-07-2021, 10:01 PM
(02-07-2021 09:24 PM)rprosperi Wrote:(02-07-2021 07:21 PM)Massimo Gnerucci Wrote: Symantec... :dodgy: Bah. Still Symantec in its roots. And Norton was Norton when it was Norton (PNC). Symantec always had the anti-Midas touch. And Broadcom still takes advantage of the Norton emblem to hook us oldtimers. ;) Greetings, Massimo -+×÷ ↔ left is right and right is wrong |
02-09-2021, 09:03 PM
(02-07-2021 01:37 PM)rprosperi Wrote:I have never had any problems accessing my sites neither with Windows (98, XP, ..., W10) nor with Linux (Ubuntu, Debian, Fedora ...)(02-07-2021 12:55 PM)Pierre Wrote: Yes, On my TI58C website ti58c.phweb.me you will find a lot of module sources ! The servers are at my home and are without known hacks (only one attack in 30 years!) http://ti58c.phweb.me http://clones.phweb.me http://www.instagram.com/ti58c "No! Do or Do not. There is no try!" [Master Yoda] |
02-10-2021, 12:20 AM
As an aside, thank you Pierre for all the hard work with your site, app and information!
Gene |
02-10-2021, 12:58 AM
(02-09-2021 09:03 PM)Pierre Wrote:(02-07-2021 01:37 PM)rprosperi Wrote: When I attempt to go to your site, my security s/w stops, prevents access and warns that "This is a known dangerous webpage."I have never had any problems accessing my sites neither with Windows (98, XP, ..., W10) nor with Linux (Ubuntu, Debian, Fedora ...) Thanks for verifying this Pierre. Unfortunately in current times, it only takes 1 person flagging a website as "bad" (perhaps a download didn't work, perhaps site access was slow, perhaps the user was really stupid....) to put it on a warning list... I flagged it as 'trusted' so this may not happen again. And yes indeed, your site is excellent, I was not aware of your 58C emulator, one of my favorite TI machines! Also, lots of ROMs and other resources. Very nice! Thanks for your hard work to create these and your generous nature to share them with the community! --Bob Prosperi |
02-10-2021, 08:33 PM
