Help on (emu48) HP49-50G: IOPAR "corrupted"
02-28-2021, 11:18 AM
Just wanted use today the transcript tool program INOUT.
Got the following error message:
TRANSIO ERROR:
Invalid IOPAR
I checked then the reserved variable IOPAR.
Its contain is the following:
{115200 External External... External},
with the term External repeated 936 times.
I looked on Interned, certainly too quickly, but could not find any solution to my problem.
Could somebody help me restore the original content of that variable? And where should I place it?
Of course, I wish not to loose my programs.
Just for your information, I do not have a real HP50G calculator, but the Emu48 version working on a Samsung Galaxy S6.
Thanks for your help.
Gil Campart
02-28-2021, 01:37 PM
RE: Help on (emu48) HP49-50G: IOPAR "corrupted"
I can't say if this is the default value, but on one of my 50g's, IOPAR is set as follows:
{115200 0 0 0 3 1}
hth
02-28-2021, 03:25 PM
It worked.
Thanks your help.
Gil
02-28-2021, 10:12 PM
(02-28-2021 01:37 PM)rprosperi Wrote:  I can't say if this is the default value, but on one of my 50g's, IOPAR is set as follows:
{115200 0 0 0 3 1}
The 50g AUR (pp. D4–D5) confirms those are the default I/O parameter settings.
Those settings correspond to:
115200 baud rate
0 no parity
0 XOFF/XON software flow control disabled for receive
0 XOFF/XON software flow control disabled for transmit
3 3-digit cyclic redundancy check for SEND
1 translate 10 (LF) to/from 10 & 13 (LF & CR)
Cambridge, UK
41CL/DM41X 12/15C/16C DM15/16 17B/II/II+ 28S 42S/DM42 32SII 48GX 50g 35s WP34S PrimeG2 WP43S/pilot/C47
Casio, Rockwell 18R
02-28-2021, 11:28 PM
(02-28-2021 10:12 PM)cdmackay Wrote:  The 50g AUR (pp. D4–D5) confirms those are the default I/O parameter settings.
115200 baud rate
0 no parity
Thanks. I could not recall what the 'extra' zero is for, I forgot or maybe never realized the flow-control could be enabled only 1 way (which seems kinda strange to me...)
