SR-52A rebuild project (SR-52A 942058 LTA4176)
03-05-2021, 09:12 AM
(This post was last modified: 03-12-2021 11:58 PM by albertofenini.)
Hi everyone
while restoring the SR.52 we have, a couple of spare units came out from our drawers these are pretty beaten up, but we should have almost all the parts we started yesterday with one of the two, and thanks to the contribution of Klaus Overhage we also have pictures of how to re-connect the card reader these models are different, probably earlier versions, from the two we restored last weekend card reader is attached in a different position and components layout is also different one doubt we have is the following : in our model close to the upper battery contacts there is a transistor, but there are also markings for another one called Q4, this is missing on both our spare units we don't recall if we removed or not, but looks like those marking are untampered ... anyone can tell us what kind of transistor is ? pictures of the restoration can be seen here : SR-52 942058 LTA4176 Edoardo & Alberto |
03-05-2021, 01:07 PM
RE: SR-52 rebuild project
(03-05-2021 09:12 AM)albertofenini Wrote: Q4 ... anyone can tell us what kind of transistor is ? Did you look in the SR-52 troubleshooting guide? http://www.decodesystems.com/TI_SR-52_Tr...ooting.pdf I have looked through it but it is difficult to tell what Q4 is - it is shown in one of the last pages. Regards Max |
03-05-2021, 02:14 PM
Thank you Max,
I have that document but it's not clear what kind of transistor is, maybe this could be a PCB revision that doesn't need it ... I do remember stripping some of the components but not that particular transistor Will work on it probably this weekend, starting by re-soldering the missing ICs and will see ! thanks again take care !!! (03-05-2021 01:07 PM)Maximilian Hohmann Wrote: Hello! Edoardo & Alberto |
03-05-2021, 03:33 PM
Q4 is used with Q3 as a Darlington pair to drive the motor on the original SR-52 model PCB.
Q1 and Q2 are used as the Darlington pair to drive the motor on the SR-52A revisions. Q4 do not have special requirements in this position, any npn high current type is adequate, see the Q2 specs on the SR-52A revision, it should be similar. I would say a npn with IC of 1 ampere maximum and VCE of 20 volt would do the job. Jose Mesquita RadioMuseum.org member |
03-05-2021, 03:39 PM
Thank you very much
However, the SR-52 troubleshooting guide never mention a Q4, it mentions a Q1, a Q2 and a Q3 I need to go back to the PCBs and take a good picture On the other side, I don't remember removing a Q4 and the holes on the PCB look really untampered Do you mean that if Q1 and Q2 are present, then Q3 and Q4 are not necessary ? Please bear in mind that on both spare units Q3 is indeed present Thanks again for help If you have any picture that would be of help In the pictures provided by another firm member, in order to reconnect the card reader, I can spot a Q4 ... (03-05-2021 03:33 PM)jebem Wrote: Q4 is used with Q3 as a Darlington pair to drive the motor on the original SR-52 model PCB. Edoardo & Alberto |
03-05-2021, 04:50 PM
A closer look at the Troubleshooting guide reveals :
so it may be that the board is missing transistor is because of that The document refers to this as a Q5 while on the PCB the marker says Q4 ... Anyone knows where can I find the version of the board ? Edoardo & Alberto |
03-05-2021, 05:16 PM
(This post was last modified: 03-05-2021 05:20 PM by jebem.)
Hi, Alberto,
The information I gave you is taken from the SR52 service guide that I bought on eBay long time ago and later I made it a available to all community thanks to Katie. Please see the schematic diagrams for both versions of the 52. I dare to link here to my own findings at the time, hope that this action will not be censured here as it was in the past with another project of mine. Please browse the pages until you see the link to Katie's website where the service manual was uploaded. Gene's thread hijacked by me on the SR-52 Wish you good luck with your project. I didn't quite restored my SR-52 as other tasks were taking my time until I forgot about it. Jose Mesquita RadioMuseum.org member |
03-05-2021, 06:28 PM
Hi Jose
thank you very much for your message and your support I had read all of the thread when I started to restore the two SR-52 that where complete and running Those two units S/N 953114 LTA4176 and S/N 014131 4775DTA are of the same version of the one you have pictured in your post, card reader is attached to the main board on the upper left corner (component side) of the PCB What kind of version is this ? SR-52 or SR-52A (just to know) The service guide you mention is the "SR-52 and SR-52A troubleshooting guide" ? If that is the one, I have it and I have read it throughly, still I couldn't find a reference to Q4 These other two units, which I had dismantled almost fifteen years ago, and of which the working status is unknown , are however of a different type, they have four green capacitors in the upper left corner and the card reader is connected closer to the battery terminals These units S/N 942058 LTA4176 and S/N 086513 LTA5176 with the green capacitors which version of the SR-52 are ? Also I looked in the Etienne section of the post but I'm afraid the links are expired, images won't load and the link referenced is not working What am I missing ? Thanks for help ! (03-05-2021 05:16 PM)jebem Wrote: Hi, Alberto, Edoardo & Alberto |
03-05-2021, 08:26 PM
Hi Alberto,
I can't really tell what version I have because I am temporally away from home, taking care of my old sick parents. But I wouldn't worry to much about the version, as there are several releases of the 52 PCB (A to L, if my memory is not failing), and at least one version of the 52A, and of course several modifications were introduced, from circuit design, PCB layout, components selection (brand, floors, etc). In the manual, look for the schematics diagrams, pages 37 and 39, you should be able to find on the right side of each page a symbol for the Motor, and one terminal is connected either to Q2 or to Q4, depending on the schematic version. With a multimeter we can check where the motor is connected, it will be to a collector either to Q2 or to Q4. Jose Mesquita RadioMuseum.org member |
03-05-2021, 09:12 PM
(This post was last modified: 03-05-2021 09:52 PM by albertofenini.)
Hi everyone
I have added few more pictures to the initial link I have also mounted the TMC0501 First try to power up failed ? Has the keyboard to be connected ??? Based on the components mounted this unit should be a SR-52A Tomorrow we will try to measure few voltages and try to troubleshoot something Any suggestion is welcome !!! EDIT actually is not completely dead For a while a 20000 was blinking in the left part of the display When Turning off and on a faint -. In the most left part also lit Then only a very faint . In the left part of the display stays on I have added video of the power on to the pictures album Please keep in mind the keyboard is disconnected Pictures and videos here : SR-52 Rebuild project Edoardo & Alberto |
03-05-2021, 09:53 PM
Hi Jose, best of luck with your parents !!
(03-05-2021 08:26 PM)jebem Wrote: Hi Alberto, Edoardo & Alberto |
03-06-2021, 03:59 PM
Hi guys
We have attached a keyboard Didn’t change much but something happens At first we have got a blinking number on the left Then pushing the LRN key make a 0 to show up We started to measure and while VGG is about - 11.95 VDD is about - 6.18 and what I think is Vss (+ terminal of C10) is about VBatt WhAt do you think ? Check pictures and video here : SR-52 Rebuild project Edoardo & Alberto |
03-06-2021, 10:05 PM
(This post was last modified: 03-12-2021 11:57 PM by albertofenini.)
RE: SR-52 rebuild project (SR-52 942058 LTA4176)
Differences between SR-52 and SR-52A, testing Vdd, Vgg, Vss, Vbatt
Hello Everyone, few updates for today : we are almost certain that this unit is a SR-52A, while the two we restored are most probably SR-52 REV. D thru L we tested all of the voltages from this unit and we compared the values with those from a working SR-52 the differences are 1. a SR-52 uses a TMC0524 where a SR-52A uses a TMC0534 2. a SR-52 uses a CD4011 AND a SN96239 where a SR-52A uses only a CD4011 but all the voltages measured at every IC where identical between the two units we have also noted that Vgg in the documentation is expected to be -15 V and actually is about -12 volts for both units while Vdd in the documentation is expected to be about -10 V while in both units is about -6.24 Vss is about Vbatt for both units so we believe is ok we attached a scope and we have found the SR-52A (the one that doesn't work)has a good Clock 1 and Clock 2 signal exactly as the working SR52 in all the points where it is supposed to be current consumption is also identical between the two and is about 170 mA when showing a 0 (or for the SR-52A what is should be a 0) We have found however different waves around the TMC0501 in the non working unit However, since this is the area where the PCB was badly ruined, before removing and trying to replace that chip we would appreciate some suggestions on the possible cause of non working. Any idea ? Thanks for help !!! Take care !!! Edoardo & Alberto |
03-07-2021, 07:05 PM
(This post was last modified: 03-12-2021 11:42 PM by albertofenini.)
Replacement of the Display Driver
Another step forward ... After replacing the TMC0534 and the TMC599 with no effects we have found out that one of the SN27882 had a corroded pin which broke ... Replaced that the display turns on but ... None of the numerical keys work, it goes in LRN mode and some of the keys like the first column is ok, sto and rcl seems ok with few others ... Now the question is how can we understand if it’s a keyboard problem or a TMC534 or a TMC501 issue ?? Thanks for help !!!! Edoardo & Alberto |
03-07-2021, 07:37 PM
(This post was last modified: 03-12-2021 11:55 PM by albertofenini.)
How to find a keyboard failure
If we short with a thin wire rows and columns at the pcb side the calculator works and numbers are displayed and operations can be done However, when the few working keys are pressed on the keyboard the corresponding row and columns are not shortened together as we were expecting As an example : the LRN key works and is obtained with column 4 and row 8 If we put an ohmmeter between this two points when we press the LRN key [/align]they don’t get shortened I think we are missing how the keyboard works and this make difficult the repair Any idea ? Thanks for help !!![align=justify] Edoardo & Alberto |
03-10-2021, 11:32 PM
(This post was last modified: 03-12-2021 11:41 PM by albertofenini.)
Rebuild of the keyboard
Hi everyone !! Another small step forward We have completely dismantled the other spare unit keyboard and cleaned every single dome First tests show that all the keys are now functional We are using the wires that usually come with a breadboard in order to replace the original cable connector Next steps are now to glue back the facelift using double sided tape And reconnecting the card reader The card reader is mechanically working We have rebuilt the gummy wheel and a card is transported with constant speed across the card reader Electronically tests still to be done AAA batteries springs are on the way and will be used to replace the broken battery contacts Update pictures link here : SR-52 rebuild project Edoardo & Alberto |
03-11-2021, 11:25 PM
(This post was last modified: 03-12-2021 11:54 PM by albertofenini.)
The repair of the battery contacts, rebuild of the card reader, faceplate
Hi everyone This is the current situation Using the AAA springs we have rebuilt the battery connectors We have also glued back with double adhesive the front plate It will take now 24 hours to strengthen but it looks ok We have also reconnected the card reader However when a card is inserted nothing happens Basically the engine doesn’t start We have cleaned the card switch which was always open but still the engine doesn’t start We had previously checked the engine and if powered externally it works fine Tomorrow will check the card reader circuit starting from the U7 and will see Suggestions and ideas are very much welcome Take care !!! Update album is here : SR-52 rebuild project Edoardo & Alberto |
03-12-2021, 11:52 PM
Card reader kind of working, keyboard connected, faceplate almost done
Hi everyone today we replaced the original keyboard with the restored one Since we didn't want to fiddle too much with the pcb we decided to use a SIL socket This will be the first SR-52 with a removable keyboard ![]() At this stage there are two connectors, one will be removed before closing the unit It will also probably be necessary to modify the lower half of the case in order to accomodate the thickness of the SIL We have also cleaned the card switch and re-soldered the cables Cleaned the head and lubricated the card reader motor The good news is that card reader now start and transport the card quite well The bad news is that it doesn't read ... Will investigate what the problem could be between these possible causes : - head dirty or not working - not enough pressure between the card and the head - amplifier not working We have also given a look at the faceplate, it's not bad but it tends to detach from the upper side of the frame so we have put it under pressure again ... take care !!! Few more pictures at the usual link : SR-52 rebuild project Edoardo & Alberto |
03-13-2021, 10:00 PM
RE: SR-52A rebuild project (SR-52A 942058 LTA4176)
Card reader works, reads and writes
Hello Everyone, the card reader is now working ![]() First we disconnected the card reader and checked the resistance for every channel Yellow with Black : 681 Ohm Green with Black : 675 Ohm Orange with Black : 700 Ohm White with Black : 718 Ohm we do not have (yet) an Impedance Meter so we couldn't check those values as well but never mind, the head looked ok, we polished the face of the magnetic head with a Dremel and a cotton tool, is less aggressive than using the cleaning card which is abrasive and has the same effect as for removing the dirty patina one thing we learned todays is that rather then putting oil in order to lubricate the card reader motor (we were using WD-40) is way better to use a contact cleaner (we uses Deoxit D5) we think this is because probably the reason for a noisy and slow motor is that the electric brushes that can be seen from the bottom removing the small black cover are oxidized and the contact cleaner makes miracles, now the motor is fast and way more silent than before Then we removed the TMC0595 (our is a version D, it was printed on the bottom) We cleaned underneath and we also removed and checked all the capacitors C12,C2, C3, C4, C5 checked the nominal value and in the end we used those from the other spare unit as they were .004 microF which was closer than the original ones to the nominal value of .005 microF Meanwhile we discovered and fixed (again) the keyboard that had a loose joint for the fifth column which made Impossible to do any calculation being that the column with the operation keys and the equal key Re mounted everything and ... voila It reads all of the BA Libray and we have also been successfully copying the card BA-1 Diagnostic cards also produce the expected result Next step : check the faceplate and close everything .... We may as well try the same operation on the other spare unit, but first we need to find a good SN27882 because we took one from that unit to repair this ... It's available new on line or it can be found on all of the SR-50 models Picture and video updated here : SR-52A rebuild project (SR-52A 942058 LTA4176) Edoardo & Alberto |
03-14-2021, 12:21 AM
Real real shame the TI model card readers are 1) so comparably difficult to repair and 2) a lot fewer people care and have skill / experience repairing them.*
Put together, these two things mean most TI models with card readers that die stay dead. That's one reason I recommend the TI-58C. Most of the benefit without the dead card reader. It's also a reason my four SR-52 units will never read a card again... :-) Gene * I totally understand #2 here, just pointing out the reality. |
User(s) browsing this thread:
