Nelder Mead Optimization
03-05-2021, 04:29 PM
(This post was last modified: 12-17-2023 06:55 AM by rawi.)
Edit: Improved version
Improvements: Maximum number of iterations is set Better output 2nd Edit: Error correction in FUNCX 3rd edit: Typo in program corrected, program shortened For me one of the best things of the HP71B was the curve fit module with the possbility to optimize functions with up to 5 dimensions. This program uses Nelder Mead method to optimize functions with the number of dimensions only limited by memory. Nelder Mead optimization is a type of simplex routine that uses only values of the function. It is very robust and no derivates are needed. Preparation: Define function FUNCX() that is to optimize. FUNCX() has to take values of parameters from list L1 and return the function value. The program determines parameters so that function is minimized. If you want to maximize use the negative. Put in starting values for the optimization process in List L1. See that the list has the same dimension as the dimension of the problem. Program asks for the initial step-width S0 for the computation of the starting simplex (e.g. 0.5), for the termination criterion E0 (small number, e.g. 1E-5) and for the maximum number of iterations (e.g. 200). Type them and press OK. Screen shows number of iterations, minimum reached so far and mean difference between simplex points and stops after the mean difference between points is less than termination criterion E0. Result: fmin: Function value at optimum in Y Parameters: D0 = Dimension (min: 2, is taken from size of L1) S0 = Starting step width for simplex (e.g. 0.5) Y = Value of function L1 = List of x values (at the beginning starting values, at the end result) L2 = Reflection point coordinates L3 = List of function values of simplex E0 = Termination criterion (if average side length of simplex is smaller, process stops) M1 = Matrix of simplex Example: Minimize the following function for the parameters x1-x5:: f(x1,x2,x3,x4,x5) = (x1-2)²+(x2-1)²+(x3-1.5)²+x4²+(x5+1)²+2*((x1-2)*(x2-1))^2+0.5*((x2-1)*(x5+1))^2 Exact solution is x1 = 2, X2 = 1, X3 = 1.5, X4=0 and X5 = -1 with f =0. Type in the following program: Function FUNCX(): EXPORT FUNCX() BEGIN LOCAL Q1; (L1(1)-2.)^2+(L1(2)-1)^2+(L1(3)-1.5)^2▶Q1; Q1+L1(4)^2+(L1(5)+1)^2▶Q1; Q1+2*((L1(1)-2)*(L1(2)-1))^2▶Q1; Q1+0.5*((L1(2)-1)*(L1(5)+1))^2▶Q1; RETURN Q1; END; We take {0,0,0,0,0} as starting value. Put this in list L1. If there are more than 5 cells in L1 delete them. Execute NMO. You are asked for S0 and E0 and maximum number of iterations ITM. We take S0=0.5 and E0=1.E-5 and ITM=200. Press OK. Program shows minimum reached during computation and stops after a few seconds with the message “DONE” and number of Iterations (159), Termination criterion (6.23E-6), Minimum Function Fmin (1.44E-11) and difference between maximum and minimum in simplex (1.2E-10). So it has converged. Result: List 1 shows: 2.00000, 1.00000, 1.50000, -1.8984E-6, -1.00000 Code: EXPORT NMO(S0,E0,ITM) |
