hp 17bII+ cosine, tan trig functions
03-06-2021, 08:11 PM (This post was last modified: 03-06-2021 08:13 PM by Lonewolf.)
I just just keyed in the sine function I found from Gerson W. Barbosa in a 2006 posting:
SIN=L(SX:X*(5.8177641733
1E-3+L(X2ConfusedQ(X))*(-3.281
8376137E-8+G(X2)*(5.5539
1606E-14+G(X2)*(2.0935E-
26*G(X2)-4.47566E-20))))
)*(3-4*SQ(G(SX)))
...and it works just fine... My question is, how do I key in these two simple identities in the solver function as an equation:
cos x = sin(90 - x)
tan x = sinx / cosx
I am not a programmer; any help would be appreciated.
/Silicon Valley Regards
Attached File(s) Thumbnail(s)
03-07-2021, 09:21 AM
RE: hp 17bII+ cosine, tan trig functions
(That is, from Gerson's Fast and Accurate Trigonometric Functions on the HP-17BII)
(Sorry, can't help with the main question)
03-07-2021, 12:08 PM (This post was last modified: 03-07-2021 12:10 PM by Gerson W. Barbosa.)
(03-06-2021 08:11 PM)Lonewolf Wrote:  I just just keyed in the sine function I found from Gerson W. Barbosa in a 2006 posting:
1E-3+L(X2:SQ(X))*(-3.281
)*(3-4*SQ(G(SX)))
cos x = sin(90 - x)
tan x = sinx / cosx
Unfortunately there is no way to do what you intend because SIN(X) is not a built-in function. If you want to have COS(X), for instance, you should rewrite the above equation replacing every occurrence of the argument X with (90-X):
COS=L(SX:(90-X)*(5.8177641733
1E-3+L(X2:SQ((90-X)))* ...
This should work on the original HP-17B and HP-17BII, but not on the hp17bII+, if I am not mistaken, because of a flawed reimplementation of the solver on the latter.
I have written a very long equation that handles the basic three trigonometry functions and their inverses, plus degrees<>radians conversions, but it won’t work on the hp 17bII+. This thread from 2014 includes an attached file that you might want to try on the Emu42 emulator, though:
A very long HP-17BII equation - Update
Gerson.
03-07-2021, 08:32 PM
(03-07-2021 09:21 AM)EdS2 Wrote:  (That is, from Gerson's Fast and Accurate Trigonometric Functions on the HP-17BII)
Thank you for the extra information.
03-07-2021, 09:01 PM (This post was last modified: 03-07-2021 09:03 PM by Lonewolf.)
[attachment=9183]
)*(3-4*SQ(G(SX)))
cos x = sin(90 - x)
tan x = sinx / cosx
1E-3+L(X2ConfusedQ((90-X)))* ...
Gerson.
Thank you; in the meantime, I am thinking of the possibility of a clamshell configuration idea of my hp 17bII+ and my TI-36X Solar (which I carry for the trig and inverse trig functions)... But I have keyed in the Law of Cosines, angle between vectors, and other geometric equations into my hp 17's equation library...
