MyBB SQL Error
06-19-2014, 08:08 AM
MyBB SQL Error
This morning I got this message when opening the MoHPC portal: MyBB SQL Error MyBB has experienced an internal SQL error and cannot continue. SQL Error: 1203 - User hpmuseum already has more than 'max_user_connections' active connections Query: [READ] Unable to connect to MySQL server Please contact the MyBB Group for support. On the second try, it worked fine. Cheers, Jose Jose Mesquita RadioMuseum.org member |
06-19-2014, 09:37 AM
RE: MyBB SQL Error
(06-19-2014 08:08 AM)jebem Wrote: Hi, For me it was on the fourth try, much later on... Greetings, Massimo -+×÷ ↔ left is right and right is wrong |
