Serious bug in beta 4/16
04-18-2021, 06:58 PM
Reporting this here as it's a real showstopper.
All command instantiations on the CAS home are prepended by the word CAS. Obviously, this should only happen on the Numeric home screen. If the user doesn't first delete the CAS header, all functions fail on the CAS home screen. This bug is present on both the hardware and emulator. |
04-18-2021, 07:21 PM
RE: Serious bug in beta 4/16
Yeah, I'm seeing the same thing...
ENTER > = |
04-18-2021, 07:49 PM
Everything looks and works normally on my G2. I even tried multiple CAS settings but still could not reproduce. Perhaps try resetting the calculator?
Cemetech | YouTube |
04-18-2021, 08:29 PM
(04-18-2021 06:58 PM)jonmoore Wrote: Reporting this here as it's a real showstopper. I don't have that problem on my G2 or my emulator. I'm using these settings: Angle Measure: Radians Number Format: Standard Integers: Decimal Simplify: Minimum Exact: on Complex: on Use √: on use i: on Principal: on Increasing: off Recursive Evaluation: 25 Recursive Replacement: 1 Recursive Function: 100 Epsilon: 0.000000000001 Probability: 1e-15 Newton: 60 Tom L Cui bono? |
04-18-2021, 09:10 PM
I do have the same problem on my G2 unit. Same example CAS.solve in CAS mode. Tried to insert same settings above described but still no changes. How strange.
04-18-2021, 09:21 PM
Tried resetting and cold rebooting still the same problem. BTW should have mentioned this before, my unit is a G2 too.
I’ve rolled back to an earlier firmware for now and will start testing again with the next build. |
04-19-2021, 06:36 AM
found and fixed for next version. Thanks. Cyrille Although I work for the HP calculator group, the views and opinions I post here are my own. I do not speak for HP. |
04-19-2021, 09:36 AM
(This post was last modified: 04-19-2021 10:53 AM by toml_12953.)
(04-19-2021 06:36 AM)cyrille de brébisson Wrote: Hello, If I may ask, why doesn't the bug appear on some calculators? The reason I ask is because I wonder if the fix will break it on those machines on which it works now. Tom L Cui bono? |
04-19-2021, 10:41 AM
RE: Serious bug in beta 4/16 | |||
04-19-2021, 02:17 PM
It was an uninitialized variable issue.. a flag that was meant to indicate if the CAS. prefix was needed was not always initialized... Depending on what you had in RAM prior to using the function, you could get this or that happening... Cyrille Although I work for the HP calculator group, the views and opinions I post here are my own. I do not speak for HP. |
04-20-2021, 12:36 PM
