Key for stopping Python program (endless loop)
04-20-2021, 08:15 PM
Hi all,
I tested a very simple Python program, with input() and print() in a while 1==1 endless loop. Does any of you know with which key (or combinations) the program can be stopped and returns to the program editor. Okay, I have now done it with a paperclip reset, pfff — Dirk Hartland |
04-21-2021, 07:39 AM
(This post was last modified: 04-21-2021 07:40 AM by cyrille de brébisson.)
RE: Key for stopping Python program (endless loop)
ON+Symb will also do a reset of the calc.. Then if you go back to num, make sure that you do not let the program run by cancelling the "import and run" message box! I will see if I can implement an "ON" detection that will raise a kbd exception Cyrille Although I work for the HP calculator group, the views and opinions I post here are my own. I do not speak for HP. |
04-21-2021, 08:16 AM
Hi Cyrille,
Thanks for your quick reply. ON+SYMB gave a reset, after the reset my “stupid” program was immediately restarted. An ON+another key would be perfect to terminate a program. — Dirk Hartland |
04-22-2021, 05:45 AM
Press and hold backspace at boot time should avoid the program re-running at reboot. For the next version, I have added an ON key detection system... Cyrille Although I work for the HP calculator group, the views and opinions I post here are my own. I do not speak for HP. |
04-22-2021, 06:55 AM
Cyrille, Thanks !!
— Dirk Hartland |
