Percentage Problem not found in the manual
04-24-2021, 01:23 PM
(This post was last modified: 04-24-2021 01:29 PM by Gamo.)
I have put some "Percentage Problem" for some compatible calculator.
These Percentage Problem not found in most of the manual such as Percent of Total, Pricing Calculations etc. This Percentage Problem I used the Casio MS-20UC with this calculator to calculate Percent addition or subtraction it use this steps: amount [x] rate [%] then [+] or [-] style. Also this calculator must have constant arithmatic when double press for example [+] [+] the display will shown little k on screen. Here is the PDF file: https://www.dropbox.com/s/p8pqirx8aadhlk...m.pdf?dl=0 Recommend to print this out. Gamo 4/2021 |
