HP Prime reboots in Spreadsheet [solved]
04-25-2021, 10:36 AM
(This post was last modified: 04-27-2021 03:06 PM by toitoise.)
Since the activity around HP Prime's Firmware restarts as never seen before, I would like to know if I'm the only one to have this issue with SpreadSheet or if it is something already known in the Hp Prime's Bug list. It is very easy to reproduce, just open a SpreadSheet, then press 'Go To' and 'Ok'.... And the calculator is rebooting. I repoduced the same behavior with the Emulator. Could you address this issue, if confirmed it is not just my Prime's issue, in the current Firmware evolution. I would just mention that it's not a behavior due to the current major evolution, it was existing before. Thanks to the HP community |
04-25-2021, 01:57 PM
(This post was last modified: 04-25-2021 01:58 PM by dg1969.)
RE: HP Prime reboots in Spreadsheet
Same crash as you describe on G2 calc. FW 2.1.14558
04-25-2021, 02:40 PM
(04-25-2021 01:57 PM)dg1969 Wrote: Same crash as you describe on G2 calc. FW 2.1.14558 Confirmed here on a G2 too. Although one has to congratulate HP for the elegance and speed of the reboot routine. It appears the crash is related to a lack of error checking for situations where the entry field contains no data and the user presses OK. |
04-25-2021, 04:31 PM
(This post was last modified: 04-25-2021 04:34 PM by rawi.)
Same behavior with G2 software version 2.1.14433 and OS V2.060.650
but not with G1 software version 2.1.14425 and OS V0.050.640 |
04-26-2021, 08:17 AM
thanks!
Empty string not tested for! until next release. Cyrille Although I work for the HP calculator group, the views and opinions I post here are my own. I do not speak for HP. |
04-26-2021, 07:33 PM
Thanks everyone for confirming the behavior and I cross fingers for next release.
I also had in mind the lack of testing empty field so not a too difficult bug to solve (I hope so). My concern was also in case of the Exam mode activated, can the reboot deactive it ? |
04-26-2021, 08:09 PM
(04-26-2021 07:33 PM)toitoise Wrote: Thanks everyone for confirming the behavior and I cross fingers for next release. The release that fixes that came out today. Tom L Cui bono? |
04-27-2021, 03:00 PM
Tested and approved !
Thanks a lot. |
