2021: INPUT for CAS Mode
05-01-2021, 06:22 PM
(This post was last modified: 05-09-2021 10:08 PM by compsystems.)
Hello, INPUT cms does not work in CAS MODE, the following code although it is for home mode, it can be executed in CAS mode
try to test input_(x) then type '987' in single quotes, in the end the input variable is not stored in memory = (any way to do it? PHP Code: export input_(var) |
05-01-2021, 08:47 PM
RE: INPUT for CAS Mode
(05-01-2021 06:22 PM)compsystems Wrote: Hello, INPUT cms does not work in CAS MODE, the following code although it is for home mode, it can be executed in CAS mode Where's the end of the if? Tom L Cui bono? |
05-02-2021, 05:07 AM
updated code.
