MacOS Big Sur
05-03-2021, 06:17 AM
MacOS Big Sur
Do the latest versions of the HP Connectivity Kit and Prime Emulator work on MacOS Big Sur with the new M1 chip?
Thanks, Wally |
08-14-2023, 12:30 PM
(This post was last modified: 08-14-2023 12:31 PM by Mark Power.)
RE: MacOS Big Sur
I'm using Build: 2.1.14425 (2020 1 16) on an M1 with BigSur and now Ventura, though it is very buggy. Simply disconnecting the calculator from the Mac crashes the Connectivity Kit. Remember to save your work often!
08-14-2023, 07:15 PM
RE: MacOS Big Sur
I find Connectivity Kit on my intel base Mac becomes unresponsive when left idle for some time, and using the Simulator the fans pick up as it consumes a lot of energy, even sitting there idle it’s eating up the battery power as it’s CPU usage is high not a great app to leave running tho i only use these apps briefly to test an app on the simulator or transfer files from the Mac and HP Prime
