Integration in Python
05-08-2021, 04:07 PM
Hello, how can i insert an integral in python? For example:
05-08-2021, 04:45 PM
RE: Integration in Python
In reality, the calculation of the integral, with extremes equal to "xx = 0" and "yy = 3", instead of being equal to 9/2, becomes equal to "yy^2/2 - xx^2/2". How can I express, in the integral, the values given to "xx" and "yy"?
05-08-2021, 05:34 PM
(05-08-2021 04:45 PM)robmio Wrote: gg=caseval("int(x,x,xx,yy)") You need to interpolate the string >>> xx, yy = "0", "3" >>> "int(x, x, {0}, {1})".format(xx,yy) 'int(x, x, 0, 3)' |
05-08-2021, 07:16 PM
it works! Thanks so much! Another question: the result appears in the "Terminal" screen: how can I get the result in the "CAS" screen?
05-08-2021, 07:42 PM
Also, why is it an error if I set the extremes "xx = 0" and "yy = 1000"? In fact, if I set the upper extreme to "999", the result is right.
