HP41CL, Image Identifiers in excel format, Page 49 in Manual,
05-09-2021, 04:27 PM
does anybody have this table (HP41CL, Manual, pages 49 - 60) in excel file format or anything else, that I can transfer into excel? I broke my fingers trying to do this with the PDF file. Greetings Uli |
05-09-2021, 06:28 PM
RE: HP41CL, Image Identifiers in excel format, Page 49 in Manual,
You can try it with
https://online2pdf.com/de/pdf-zu-excel-konvertieren# Sorry to disturb you..... I have tried to delete my thread, unfortunately I do not have the permission . Greeting. |
05-09-2021, 06:29 PM
Better use the mem_ref_v5.txt (or the one that matches your configuration) file that comes with every download package of ROM files (latest is always in the File Area of teh 41CL website). This is a semicolon separated text file that will import easily in Excel. And up to date!
Regards, Meindert |
05-09-2021, 08:43 PM
(This post was last modified: 05-10-2021 05:25 PM by Uli.)
(05-09-2021 06:29 PM)MeindertKuipers Wrote: Better use the mem_ref_v5.txt (or the one that matches your configuration) file that comes with every download package of ROM files (latest is always in the File Area of teh 41CL website). This is a semicolon separated text file that will import easily in Excel. And up to date! Yea, that’s it. Works. Thank you! Uli |
05-12-2021, 10:47 AM
It worked quite well for me, FWIW I have attached my current file showing the modules I was involved with either in writing (blue background) or compiling (yellow background). Quite a ride...
"To live or die by your own sword one must first learn to wield it aptly." |
05-12-2021, 12:47 PM
(05-12-2021 10:47 AM)Ángel Martin Wrote: It worked quite well for me, FWIW I have attached my current file showing the modules I was involved with either in writing (blue background) or compiling (yellow background). Quite a ride...Impressive would be an understatement, mind-blowing is a more appropriate term here, thank you Ángel for your amazing contribution. |
05-14-2021, 05:08 PM
(05-12-2021 10:47 AM)Ángel Martin Wrote: It worked quite well for me, FWIW I have attached my current file showing the modules I was involved with either in writing (blue background) or compiling (yellow background). Quite a ride... Hi Ángel, thanks a lot for that. Much better than my self made file. Uli |
05-14-2021, 05:11 PM
From time to time I take a look on the page from Jürgen Keller.
There I found https://calc.fjk.ch/library/sy41cl-image...fiers.html Surprise:-) Pure coincidence Thanks for make such an overview. |
05-15-2021, 10:06 AM
(05-14-2021 05:11 PM)Uli Wrote: From time to time I take a look on the page from Jürgen Keller. Probably not up to date because I currently don't spend much time with my calculators. |
