FIX_ _ on HP41 (fixed point display)
05-09-2021, 05:13 PM (This post was last modified: 05-09-2021 05:17 PM by aurelio.)
Sorry for the trivial question,
On the HP41 the function FIX when used prompts you for a single digit (from 0 to 9), but I've noticed that in a particular configuration prompts instead for two digits (_ _), this is sure due to the modules loaded, but why ?
05-09-2021, 06:53 PM
RE: FIX_ _ on HP41 (fixed point display)
The ZENROM and maybe others let you do FIX 10.
http://WilsonMinesCo.com  (Lots of HP-41 links at the bottom of the links page, at http://wilsonminesco.com/links.html#hp41 )
05-09-2021, 08:58 PM (This post was last modified: 05-09-2021 09:00 PM by aurelio.)
Thank-you Garth, and sorry for my bad english, I realize now a mistake in the question....it should be "which" (modules) and not "why"..., but you understood..
So maybe the ZENROM is not the one which allows FIX10...
05-10-2021, 06:32 AM
(05-09-2021 05:13 PM)aurelio Wrote:  Sorry for the trivial question,
The SandMath adds one field to the single-digit prompts, this may be the cause in your system if you have it plugged in. This is mantioned in page #44 of the SandMath Manual.
05-12-2021, 03:47 PM
Thank-you Angel.
I've cheched it, but sure I had noticed it with the ZENROM, 'cause, if I'm not wrong it was not so with the previous SM release.
Aurelio
