Update of Emu71/Win to v1.14
05-19-2021, 05:32 PM
Emu71/Win v1.14 is a maintenance update available at https://hp.giesselink.com.
This update improve the HP-IL handling of a broken loop between emulator and first virtual device. Sending a character to a first non answering device takes about 1.8s as timeout of the failed TCP/IP connect try. The actual version v1.14 has a total timeout of 20ms. This may cause trouble when Emu71 will run on a PC in Europe and the 1st virtual device on a PC in Australia, then the connect timeout maybe too short. Connects with programs running on the same PC or on a PC in the same local network have regular connect times <1ms. You may try this by opening a command shell and execute 'ping localhost'.
J-F also send me an update of his French keyboard macro include file avoiding some problems with autorepeated keys. The updated file is part of the complete installation package or of the basic KML script package skn71b.zip.
05-19-2021, 05:43 PM
RE: Update of Emu71/Win to v1.14
(05-19-2021 05:32 PM)Christoph Giesselink Wrote:  Emu71/Win v1.14 is a maintenance update available at https://hp.giesselink.com.
Wow, I gotta up my Virtual HP-IL game if folks are connecting between Europe and Australia! Wink
Thanks for the update Christoph! Smile
05-23-2021, 04:25 PM (This post was last modified: 05-23-2021 11:49 PM by compsystems.)
Please for EMU48 CG and others can you contribute to the last part that remains to be emulated (serial communication).
Quote:dd the serial port support (via USB OTG).
TODO: When stop the app, Serial exception seems to delay the save of the calc state!!!!
TODO: Inform if the connection is not possible.
TODO: What's happen if I hot unplug?
https://github.com/dgis/emu48android/blo...ReadMe.txt
05-23-2021, 04:55 PM (This post was last modified: 05-23-2021 05:21 PM by Dave Frederickson.)
(05-23-2021 04:25 PM)compsystems Wrote:  Please can you contribute to the last part that remains to be emulated (serial communication).
So you're complaining that Christoph is spending time on Emu71 rather than Emu48?
Edit: It looks like you posted to the wrong thread. Your post seems to be following this thread, instead.
https://www.hpmuseum.org/forum/thread-12540-page-9.html
