bug xCas limit
05-23-2021, 11:41 AM
bug xCas limit
Hi everyone, maybe I discovered a bug in xCas: the following limit results in "zero" instead of "-1":
limit (cos (x) / (x-pi / 2), x = pi / 2) Try to calculate it both with "HP PRIME" and with Giac xCas. Best regards, Roberto |
05-23-2021, 05:31 PM
RE: bug xCas limit
For XCas, replacing variable x to others seems to help.
XCas> f(a) := limit(cos(t+pi/2-a)/(t-a), t=a) XCas> f(pi/2) → -1 XCas> f(pi/3) → -1 XCas> f(0) → -1 Cas> f(a) := limit(cos(t+pi/2-a)/(t-a), t=a) Cas> f(pi/2) → 0 Cas> f(pi/3) → 0 Cas> f(0) → -SIN(a)/a ??? |
08-12-2021, 12:03 AM
(This post was last modified: 11-10-2022 11:45 PM by Albert Chan.)
RE: bug xCas limit
Another XCas limit bug (for HP Prime Cas, limit crashes)
XCas> asinh(x) → ln(x+sqrt(x^2+1)) XCas> asinh(i) → ln(i) = ln(abs(i)) + i*arg(i) = i*pi/2 XCas> limit(asinh(i*x), x=1) "Limit: Max order reached or unable to make series expansion Error: Bad Argument Value" Udpate Nov 10,2022: I upgraded to XCas 1.9.0-22 (win32). OP bug now fixed. However, asinh limit bug remain. XCAS> limit (cos(x)/(x-pi/2), x = pi/2) → -1 |
