Test the extent of Capabilities.
05-27-2021, 10:12 PM
I was testing what the CAS mode could do, and tested, by trial and error, how high of a power I could put to 999999999, and it turned out to be 287, 288 returned undefined.
Just to see how long it might take, I then typed in 288th Root of the previous mentioned answer. Now the G2 will not let me halt execution, turn off or anything. It is stuck with 22:56 on the clock, and it is now 23:11. When might I expect that I will be able to use the calculator again? The hourglass is still moving, so it hasn't visibly crashed. |
05-28-2021, 05:56 AM
RE: Test the extent of Capabilities.
Have you tried poking a paperclip into the Reset hole in the back?
<0|ΙΈ|0> -Joe- |
05-28-2021, 12:48 PM
RE: Test the extent of Capabilities. | |||
