HP 48GX Flag Tests
06-05-2021, 02:51 AM
HP 48GX Flag Tests
Why FC?C, but no FS?S flag test?
06-05-2021, 09:12 PM
RE: HP 48GX Flag Tests
(06-05-2021 02:51 AM)MNH Wrote:  Why FC?C, but no FS?S flag test?
Because all flags are reset at rest, and therefore have to be reset again after a test. A flag set indicates a certain condition, both with a system flag and a user flag, and a reset flag indicates the absence of that condition. With user flags, you determine the function for a flag, usually in programming. Therefore, there is no point in leaving a flag set if your program ends. Exceptions to this are system flags that you have already set while setting up your calculator. Therefore no FS?S instruction is present.
I use HP-16C, WP-34S emulator, HP-35s, HP-48GX, HP-50g, and HP Prime G2.
06-05-2021, 11:16 PM
(06-05-2021 09:12 PM)cahlucas Wrote:  Therefore, there is no point in leaving a flag set if your program ends.
Great logic! Thank you!
