Calculations history in RPN mode,
06-06-2021, 09:20 PM
Is there a way to have RPN mode keep the calculations you have just performed in the stack, preferrably on the other side of screen, like algebraic mode does?
I would like to get used to RPN and in case I may enter the wrong numbers or maths sign, I would like to know what I entered.
Algebraic mode has this feature, I get that, but programming the calculator doesn't seem to lend itself to ALG mode very well, programming seems to be geared towards RPN mode.
06-06-2021, 10:51 PM (This post was last modified: 06-07-2021 03:37 AM by Steve Simpkin.)
RE: Calculations history in RPN mode,
The short answer is no. By its nature, objects on the stack are "consumed" when a function is performed and are (usually) replaced with the answer as the stack is shifted down. The RPN models only had a four register hardware working stack and would not have had room for a history anyway. The later RPL models (like the HP 50g) had a stack that was only limited by available memory but the philosophy was similar to the RPN models in maintaining a stack discipline that replaced arguments with the answer.
On the HP 50g, the keyboard command CMD (left-shift, HIST) will show you the last four arguments entered.
06-07-2021, 06:16 AM
One way would be to use a printer. E.g. with Olivier De Smets Android app go41cxt you could have the printer in Trace-mode, and then follow the history of your calculation.
Of course this works with the original printer as well, or with the HP-97 (and other calculators with inbuilt printer).
Cheers, Thomas
[35/45/55/65/67/97/80 21/25/29C 31E/32E/33E|C/34C/38E 41C|CV|CX 71B 10C/11C/12C/15C|CE/16C 32S|SII/42S 28C|S 48GX/49G/50G 35S 41X]
06-07-2021, 01:11 PM
"Modern" RPL calculators like the 48G or 49/50g also have an undo function where you can undo the last operation (stock firmware) or even more than one step (newRPL).
06-07-2021, 06:35 PM
As TomasF suggests, any RPN hardware with a printer will do.
That's the reason for the TRACE mode of these printers, to have a printed trace of each operation in order to follow and be able to verify all operations.
