Python OOP broken?
06-23-2021, 08:51 PM
Python OOP broken?
Whenever I try to call a class method, the interpreter sometimes doesn't recognize that the "self" parameter is implied. most of my tests worked fine, but one certain case gave me an error:
Traceback (most recent call last):
  File "<stdin>", line 1, in <module>
  File "main.py", line 5, in <module>
  File "game.py", line 20, in __init__
TypeError: initialize() takes 1 positional arguments but 0 were given
(In case you're wondering, I am trying to recreate the popular board game Risk.)
Here is my code so far:
main.py:
import player
import game
from hpprime import *
Game=game.RGame()
fillrect(0,0,0,320,240,0x90c0ff,0x90c0ff)
blit(0,0,0,2)
for p in Game.players:
  p.initialize()
game.py:
import player
class RGame():
  def __init__(self):
    eval('G2:=AFiles("board.png")')
    self.playerCount=3
    self.multiplayer=False
    startTroops=[40,35,30,25][self.playerCount-2]
    self.players=[]
    for i in range(self.playerCount):
      if self.multiplayer==True or self.playerCount==0:
        self.players.append(player.HumanPlayer)
      else:
      p=self.players[-1]
      p.troopsToDeploy=startTroops
      p.initialize()
      self.players[-1]=p
      print(str(p))
  def render(self):
    blit(0,0,0,2)
player.py:
class Player():
  def __init__(self, id):
    self.id=None
    self.occTerritories=[]
    self.TroopsToDeploy=0
  def __str__(self):
    return "id: "+str(self.id)+"\nTroops to deploy: "+str(self.TroopsToDeploy)
  def placeTroops(self):
    pass
  def initialize(self):
    self.placeTroops()
class HumanPlayer(Player):
  def __init__(self):
    self.object_variable= 1
    print("place your troops")
Is it a problem with my code, the interpreter, or both?
06-23-2021, 09:20 PM (This post was last modified: 06-23-2021 09:23 PM by Albert Chan.)
RE: Python OOP broken?
(06-23-2021 08:51 PM)jfelten Wrote:  self.players.append(player.HumanPlayer)
You might need to create a class instance:
self.players.append(player.HumanPlayer())
