[Help] CPM
06-26-2021, 11:35 AM (This post was last modified: 06-26-2021 11:37 AM by hp41cx.)
[Help] CPM
How copy "HP 82900A System Disk" from ":D700" 5 1/4 drive to ":D760" 3 1/2 drive. Thanks
Systems Analyst
48G+/58C/85B/PC1500A
TH-78A/DooGee S9
Focal & All Basic´s
06-26-2021, 12:53 PM
RE: [Help] CPM
Are they both the same size disks?
If so, and also I assume you are using Series-80 (it's not stated):
COPY ":D700" TO ":D760"
should work.
06-26-2021, 01:12 PM
RE: [Help] CPM
(06-26-2021 12:53 PM)rprosperi Wrote:  Are they both the same size disks?
should work.
5 1/4 to 3 1/2
Systems Analyst
TH-78A/DooGee S9
Focal & All Basic´s
06-26-2021, 03:08 PM
RE: [Help] CPM
Doesn't PIP work from inside CP/M?
pip b:=a:*.*[ORV]
b target disk, a source disk
O binary transfer
R copy system files
V verify each block
Greetings,
    Massimo
06-26-2021, 08:05 PM
RE: [Help] CPM
should work.
5 1/4 to 3 1/2
Of course, you did write that, I am asking about formatted size, e.g. SS/DD or DS/DD, etc.
Also, the target disk must be formatted before you do the copy, it is not a sector-by-sector copy, it's file-by-file, and the target is expected to be formatted by the INITIALIZE command.
