Script file for NewRPL
07-28-2021, 04:11 AM
(This post was last modified: 07-28-2021 04:19 AM by compsystems.)
Hello
Calculators of nowdays are based on independent input and output lines, or program execution. Why not create a new way to read and run statement scripts? In hp-prime I can create a script, but I cannot store or export the sequence as a text file. Xcas can do it export as and import text (script) file . I want to see the possibility of a script file for newRPL in RPN syntax, by now with a numeric engine. The following link shows script in the hp-prime https://www.hpmuseum.org/forum/thread-16...light=xcas PHP Code: (a*x^2+b*x+c) = 0; |
07-29-2021, 03:01 PM
RE: Script file for NewRPL
An RPL program is a script of the steps you take to solve the problem.
I think you mean capturing keypresses to generate a program with the input? Could be done but I don't see a big need for it because RPL is so close to the keystrokes you need to do anyway. |
