FRAM71/B Configuration Spreadsheet [2021-10-23]
07-31-2021, 04:22 AM
(This post was last modified: 10-23-2021 04:11 AM by Sylvain Cote.)
This article is a follow up of the forum thread: FRAM71 : Configuration Spreadsheet [2021-01-31]
Preamble Daniel Simpson is the original instigator of the FRAM71 configuration spreadsheet project. As he was thinking to drop his project, I took his idea and decided to give it a shot. The major difficulty when doing this kind of problem with a spreadsheet, is to have formulas that can validate the integrity at all levels (chip, module and FRAM71/B unit). I have done several implementation of the spreadsheet between January 2021 and July 2021, all of them had chip level integrity, but until this one, all completely or partially failed at module level and/or at FRAM71 unit. FRAM71/B User's Manuals:
Slides used for the configuration spreadsheet presentation done at the HPCC 2021 mini-conference virtually held on October 23, 2021 Introduction The goal of this spreadsheet is to create safe FRAM71/B module configuration string and to let the spreadsheet validate invalid or inconsistent options. The spreadsheet currently support FRAM71 and FRAM71B modules. For each FRAM71/B configuration that you do, I suggest that you duplicate the Template tab and do your configuration in the duplicated tab. FRAM71/B Configuration Worksheet FRAM71/B Configuration Information FRAM71/B Configuration Test Suite Sheet #5 - Valid Double Chips Module - FRAM71 FRAM71/B Configuration Test Suite Sheet #7 - Invalid Double Chips Module - FRAM71 FRAM71/B Configuration Test Suite Sheet #9 - Invalid Values - FRAM71/B Doing your first configuration
Configuration samples I have reproduced the multiple configuration strings that was used in my old FRAM71 Configuration Example (Intermediate Level) article. Configuration Steps:
I hope you like it! Sylvain Article update log
