SADHP
08-22-2021, 07:40 AM
SADHP
Has anyone here been able to use SADHP on a modern machine? I've tried with SADHP 1.05 (https://www.hpcalc.org/search.php?query=sadhp) and got it running. While it does return some output it clearly doesn't work. I've probably made a mistake while fixing the ancient C code. Anyone else who has a working copy?
2xHP48GX, HP 50g, two Retrotronik ram cards, DM42
/Daniel Lidström
08-25-2021, 12:50 PM
RE: SADHP
(08-22-2021 07:40 AM)dlidstrom Wrote:  Has anyone here been able to use SADHP on a modern machine? I've tried with SADHP 1.05 (https://www.hpcalc.org/search.php?query=sadhp) and got it running. While it does return some output it clearly doesn't work. I've probably made a mistake while fixing the ancient C code. Anyone else who has a working copy?
This might help: https://bitbucket.org/pdo/sad48/ . It's a git repository I created a few years ago to hold SADHP 1.05 and Han's modifications from that time. I also applied a few modifications of my own to the Emacs Lisp code to make it play better in a typical setup (e.g. not override user C-c key bindings).
Paul
09-02-2021, 07:51 PM
RE: SADHP
Hi Paul! I got it working now, after updating sport.c to not skip any leading nibbles. Thanks!
/Daniel Lidström
