Fractional Part - A Difficult Integral
06-29-2014, 11:36 AM
Here some results for integrating FP from zero to 5.8:
Maple V Release 3.0
evalf(int(frac(x), x=0..5.8)) 2.820001887
Maxima 5.23.2
quad_qags(x-floor(x), x, 0, 5.8) [2.720000001263673,1.5265947617137954*10^-
8,3171,0]
PARI 2.4.2
intnum(x=0,5.8,frac(x)) 2.770657207613055496607250297
WolframAlpha 2011-5-28
integrate(frac(x),x,0,5.8) 2.82
CASIO fx-9860GII (& fx-5800P)
∫_0^5.8▒〖Frac X〗 dx 2.72
HP 42S
Gauss-Lagrange 16 point:
Divisions: 1 2.32
2 2.71441362769
3 2.95110930932
4 2.84122268726
5 2.72066778956
6 2.8405122545
HP 50G
Inbuilt integration programme: ∫_0^5.8▒〖FP(X)〗 dX
FIX 6 2.820116 in 1,232.15 seconds
Gauss-Lobatto 4 point formula with 7 and 13 point Kronrod extensions:
FIX 2 2.80
3 2.819
4 2.8199
5 2.82000
6 2.820000 in 12.34 seconds
SHARP EL-9650
∫_0^5.8▒〖fpart X〗 dxX 2.419454779
TI-84 Plus 2.53MP
fnInt(fPart(X),X,0,5.8) 2.720014333
TI-86 (tol = 1E-5)
fnInt(fPart x,x,0,5.8) 2.71992436738
TI-89 (& voyage 200 & 92(plus))
∫_0^5.8▒〖fPart (x)〗 dx 2.72000000036
06-29-2014, 11:55 AM
RE: Fractional Part - A Difficult Integral
(06-29-2014 11:36 AM)Gerald H Wrote:  Here some results for integrating FP from zero to 5.8:
Another example (apart from WolframAlpha) where a pencil and paper approach is better. Wink
Greetings,
    Massimo
06-29-2014, 05:18 PM
WP34s:
2.819612562 after several minutes
06-29-2014, 06:17 PM
Change the upper limit to 6.4 and try evaluating with the built-in integrator on any HP calculator that has one.
06-29-2014, 06:47 PM
(06-29-2014 06:17 PM)kakima Wrote:  Change the upper limit to 6.4 and try evaluating with the built-in integrator on any HP calculator that has one.
Link for the lazy: Numerical Integration on the 35S.
This is another example where most HP-calculators fail.
06-29-2014, 07:57 PM
HP 50G Gauss-Lobatto 4 point formula with 7 and 13 point Kronrod extensions:
3.0489 in 20.8 sec
06-29-2014, 09:40 PM (This post was last modified: 06-29-2014 10:36 PM by pito.)
What about to use a simple Monte Carlo method as a "pre-processor" to get a "rough estimate", ie.:
NIntegrate[x - Floor[x], {x, 0, 6.4},
 Method -> {"MonteCarloRule", "Points" -> 1000}]
returns always nice results around 3.08. So we can see whether the specific "precise" integration method with some "difficult" integrands has failed or not..
PS: another example from above posts:
NIntegrate[
 x*x*(x*x - 47*47)*(x*x - 88*88)*(x*x - 117*117), {x, -128, 128},
gives for example results around 2.72*10^16..
06-30-2014, 01:17 PM
Numerical integration of things like Frac(x)dx do not gain by using high-order rules (Simpson's, Gauss, etc.) because the first derivative is not continuous.
Monte Carlo (and quasi Monte Carlo) does no worse than its usual performance (which isn't that good anyway) as the variance (or variation) is small.
One QMC example is to use the points (2j-1)/2N for j=1,N as an N-point integration formula. Another is to use Frac(N*Sqrt(2)) as a sequence to integrate these types of functions.
The last sequence is easy to compute; just add Frac(Sqrt(2)) at each step and reduce below 1.
