41cv assembly
09-02-2021, 05:02 AM (This post was last modified: 09-02-2021 05:06 AM by dmh.)
41cv assembly
Where exactly does the following part go and what is the orientation?
The closest I can see in the very hard to see picture in the Service Manual is that it is part "20 - SHIELD, display" but no way to see the exact orientation (it's not symmetrical).
It was loose in a 41cv that had already been opened.
[Image: IMG_2183.jpg?dl=1]
Calculator Clique on YouTube
09-02-2021, 05:54 AM
RE: 41cv assembly
This picture should work for you. That plastic spacer goes at the very top of the display. You can see it in this photo, in the left image.
http://farm3.static.flickr.com/2194/2179...0d28_b.jpg
Hope this helps.
-Pat
09-02-2021, 06:56 AM
RE: 41cv assembly
Perfect - thanks!!!
(09-02-2021 05:54 AM)rocket.scientist Wrote:  This picture should work for you. That plastic spacer goes at the very top of the display. You can see it in this photo, in the left image.
Hope this helps.
-Pat
