same formula two diff results?
09-08-2021, 02:42 AM
In the attached image, you see the same formula twice differing only by putting ()'s around the negative number to which the exponent is applied. Is there something I should know here? I can see how this could really bite someone in the backside.
09-08-2021, 02:56 PM
RE: same formula two diff results?
(09-08-2021 02:42 AM)OneRanger Wrote: In the attached image, you see the same formula twice differing only by putting ()'s around the negative number to which the exponent is applied. Is there something I should know here? I can see how this could really bite someone in the backside. Read Unary minus sign Günter |
09-08-2021, 06:42 PM
(09-08-2021 02:42 AM)OneRanger Wrote: In the attached image, you see the same formula twice differing only by putting ()'s around the negative number to which the exponent is applied. Is there something I should know here? I can see how this could really bite someone in the backside. I believe this is because the Power operation has a higher precedence than the Negation operation. See the Prime's Algebraic precedence in the following post. https://www.hpmuseum.org/forum/thread-17...#pid151645 |
