How to Indent in MoHPC Forum
06-29-2014, 04:04 PM
I normally compose my posts on Notepad. My formatting is lost when I post. I noticed the # (insert formatted code) symbol on the above toolbar. Do I wrap my code in # symbols before or after I post?
Mark
06-29-2014, 04:37 PM (This post was last modified: 06-29-2014 04:40 PM by Katie Wasserman.)
RE: How to Indent in MoHPC Forum
(06-29-2014 04:04 PM)MNH Wrote:  Hello,
Mark
Click on # at the start of your code block, enter your code, then click on # again to close your code block. Alternatively, you can enter your code block, then select all the text in it, then click on # just once.
-katie
06-29-2014, 05:29 PM
(06-29-2014 04:04 PM)MNH Wrote:  Do I wrap my code in # symbols before or after I post?
No. Use a code-tag instead:
\([\)code\(]\)def gcd(a, b):
    return a if b == 0 else gcd(b, a % b)
[/code]
This results in:
def gcd(a, b):
06-29-2014, 09:54 PM
(06-29-2014 05:29 PM)Thomas Klemm Wrote:  No. Use a code-tag instead:
The # button is just inserts the code-tags, you can watch as it does this.
-katie
