HP-41C: The "1" key fails sometimes (weak contact).
09-11-2021, 09:31 PM
(This post was last modified: 09-11-2021 09:32 PM by Danito-Danone.)
Hi all, The "1" key of my HP-41C fails sometimes (weak contact). Question: Is safe... -> Can I open the "sealed" keyboard? Many thanks, D-D
09-11-2021, 09:44 PM
RE: HP-41C: The "1" key fails sometimes (weak contact).
The keyboard is attached with a lot of melted poles and I wonder if it is possible to reattach them. I don't think so.
09-11-2021, 11:40 PM
Suggest you search on De-Oxit cleaner. As a warning/hint research broken posts (a hazard in opening a HP-41), and be careful with ESD controls. No expert, but have learned much here via the forum search, and have had good luck. Need to look up threads on opening up an HP-41.
Example link to get you going on the subject: https://www.hpmuseum.org/cgi-sys/cgiwrap...ead=217869 No affiliation, but a one-stop info source to consider: https://www.amazon.com/HP41-Repair-begin...B08JJDW6HM |
09-13-2021, 11:31 AM
Hi There,
Its a pretty straight forward job on the surface. 4 screws are under the feet, remove the rear cover and you will see the processor board and the main keyboard/display pcb. You will see tiny holes in the main pcb which are located behind the keys. The method (IIRC by a guru from here Randy) was to put a drop of DeOxit over/in the hole and use a single strand of wire (stiff like from a wire brush) to go in the hole and gently rub the interior contact surface. I like to repeat it a few times while working the button. Only issue you may run into is how the processor board is attached. The older Cs will have nuts holding them to the lower posts, newer ones should just lift off. You might have to remove that board to see the hole for the "one" key. When done, reassemble and test. You might find stuff you need to fix as you go but hopefully not. They are not that fragile IMO as long as you don't force things. Take Care! Bill |
09-13-2021, 02:53 PM
Cleaning the key contact with a little Deoxit is no sweat - I've done it plenty of times myself, with great results. HOWEVER, the main risks in opening a 41 are cracking the screw posts (a few of which I've also had to repair), or dislodging/damaging the zebra connectors (had to clean the connectors pretty aggressively to get my 41CV working again after I opened it, but it's fine now).
09-13-2021, 10:11 PM
Thanks a lot, fellows! I'll try to fix this issue soon. D-D.
09-15-2021, 02:11 AM
(This post was last modified: 09-15-2021 03:51 AM by Geoff Quickfall.)
The idea here is the same as the field of medicine: do no harm! Or barring that do the least amount of harm to get the job done.
So deoxit into one of the pores on the PCA before you rip open the heat stakes. |
User(s) browsing this thread:
