New firmware 2.1.14596 (2021-10-01)
10-02-2021, 09:54 AM
I was surfing in hpcalc.org, and discovered an unexpected new firmware version, but I cannot find the new features:
G1: https://www.hpcalc.org/details/7469
G2: https://www.hpcalc.org/details/7783
10-02-2021, 03:51 PM
RE: New firmware 2.1.14596 (2021-10-01)
Interesting and unexpected.
The WAIT(-1) bug on G1 is still there, so back to (2020-01-16) version if you have any programs that use that command.
10-02-2021, 04:57 PM
Can’t go to computer to update until Monday…any new capabilities, fixes since May update for U.S. folks, or is this mainly impacting European users?
10-02-2021, 09:27 PM
(10-02-2021 04:57 PM)lrdheat Wrote:  Can’t go to computer to update until Monday…any new capabilities, fixes since May update for U.S. folks, or is this mainly impacting European users?
So far no one seems to know exactly what changes and/or fixes are in it. I updated all my Primes (A, C old kb, C new kb, and D) anyway just because I like being on the current version.
Tom L
Cui bono?
10-02-2021, 11:10 PM
I am aware of two fixes in it:
  • Fixes a memory leak in the power function
  • Fixes a bug in the derivation of the logb function
10-03-2021, 06:03 AM
This is a nice surprise! Smile
10-03-2021, 08:24 AM (This post was last modified: 10-03-2021 06:00 PM by StephanP.)
The Connectivity Kit (new or old version) does not appear to pick up the firmware update automatically. I downloaded it separately from https://www.hpcalc.org/prime/pc/ and manually replaced the files in the Firmware folder.
10-03-2021, 01:20 PM
Attention MacOS users
I was able to successfully download this latest version onto my G2 Prime using MacOS.
Pre-prequisites
  • MacOS 11.6 (BigSur)
  • HP Connectivity Kit Build: 2.1.14425 (2020 1 16) installed
  • System Preferences -> Security & Privacy -> Input Monitoring - give permission to Terminal and HP Connectivity Kit.app
  • A USB-2 hub
The USB-2 hub is vital - the upgrade would not work at all when directly connected to a USB3 port or a USB3 hub. This is a known bug.
Install steps
  • Download the 2021.10.01 firmware from https://www.hpcalc.org/details/7783
  • Upzip it and copy the contents into the "Documents:HP Connectivity Kit:Firmware:PrimeG2" folder. Copy just the individual files not any enclosing folder that may have resulted from the unzip. Delete any previous files that might be there already, first.
  • Connect the Prime to the Mac by USB cable (remembering to go through the USB2 hub)
  • Start the HP Connectivity Kit and it should more or less immediately display a popup dialog asking if you want to upgrade to the 2021.10.01 version. Say yes and wait
The upgrade should be quite quick - less than a minute to transfer the firmware (during which the Prime will display a "Do not disconnect" warning) and then 30 seconds or so to update the firmware on the Prime (during which a 3 row progress bar chart is shown).
If the calc appears to do nothing, locks up or goes back to input mode (so you can enter numbers on the keyboard for example) then you have gone wrong.
10-03-2021, 03:10 PM
(10-02-2021 09:54 AM)akmon Wrote:  I was surfing in hpcalc.org, and discovered an unexpected new firmware version, but I cannot find the new features:
Bonjour
Merci pour l'information.
Hello
Thank you for the information.
Sorry for my english
10-03-2021, 07:43 PM
(10-03-2021 01:20 PM)BruceH Wrote:  I was able to successfully download this latest version onto my G2 Prime using MacOS.
Pre-prequisites
  • A USB-2 hub
Install steps
Awesome, Bruce, it worked! Thanks a lot! I'm up-to-date! Smile
10-03-2021, 08:18 PM
(10-03-2021 07:43 PM)metawops Wrote:  A USB-2 hub
Notice it says some USB 3 ports, not all. This bug was fixed in version 1.2 and we're up to 2.1 now so it shouldn't be a problem unless you haven't updated since an ancient version.
Tom L
Cui bono?
10-04-2021, 01:39 AM
There's no 20211001 firmware on the HP FTP server; the newest is 20210505, and 20210609 for the emulator. There's also no new information in the release_info.txt in either firmware release. It's strange that they would release it with no info---in fact, where did it come from if it's not on HP's servers? Was it uploaded to hpcalc.org by a member of the software team themselves?
I see no discernable difference between this version and the last one, so it's probably just a routine bugfix update. I upgraded my G2, and its VERSION string shows "Software Version: 2.1.14596 (2021 10 01) Hardware Version: D CAS Version 1.5.0 Operating System: V2.060.650". Unfortunately, I don't remember what the last version's VERSION string was; does anyone else have it? I have a dim recollection of a different Operating System number in particular.
10-04-2021, 09:49 AM
Hi all,
This is due to a small error in the LOGB function we've come accross in The Netherlands. LOGB in PPL was not understood by the CAS, who is doing the derivative for the extremum function. Detecting LOGB in the PPL to CAS convertor fixed the problem. Some other small fixes were done in the same time. This is a first BETA update, the official one will follow soon.
Product Manager HP for MORAVIA Consulting, the EMEA & AP Licensee for HP Calculators.
http://www.hpcalcs.com
10-04-2021, 12:36 PM
(10-04-2021 09:49 AM)KlaasKuperus Wrote:  LOGB in PPL was not understood by the CAS, who is doing the derivative for the extremum function.
Fix what problem ?
Can you show an example of the bug ?
10-04-2021, 10:04 PM
Firstly, "some ports" might be true for Windows, but most Macs seem affected. Secondly, the fact that the bug was fixed in v1.2 is only relevant for those who bought their Prime with an OOTB version >= 1.2. Anyone with an earlier version and hit by the USB bug would be unable to upgrade from their ancient version, unless they knew the USB2 trick.
10-05-2021, 04:58 AM
(10-04-2021 09:49 AM)KlaasKuperus Wrote:  This is a first BETA update, the official one will follow soon.
Should't it have been labeled as such then? BETA.
10-05-2021, 02:49 PM
Waiting for complete cas commands, these are the ones that can be executed by the calculator.
mechanical binary calculator https://www.youtube.com/watch?v=NQX6irk11qA
10-05-2021, 10:14 PM
I'm a little bit confused by this software update.
I downloaded the link for G1 Here
I installed it on my G1.
The top of the release notes, I mean these are the top release notes, highest, assumedly latest, even if the date of update isn't correct, is should be October, right?:
Quote:HP Prime – Release Notes
Date Released: 2021/04/28
Internal Versions
Firmware Version: 2021 04 28 (14566)
Virtual Calculator Version: 2021 04 28 (14566)
Connectivity Kit: 2021 04 28 (14566)
Description
This release of the Prime Calculator firmware and associated PC and Mobile software delivers fixes to outstanding issues. This document is not a complete list of all changes but highlights specific items. All users of the HP Prime calculator are encouraged to upgrade for the best possible experience.
Please back up your calculator before the update. Any existing data on the device may be wiped during the update process.
Primary focus of this release are an update of the CAS, an update of the programming environment, the addition of the Python language, intelligent math and changes for the Netherland.
New features:
1. Add intelligent math to return limited symbolic results in home screen (can be disabled in exam mode)
2. Add Python app
3. Add more programming features
4. Detect sin(n*PI), cos(PI/2) and TAN(PI/2) in home mode (returns 0 or error)
5. Allow customization of a b/c keys results (can be disabled in exam mode)
6. Add a probability wizard to the toolbox/math/proba menu
7. Add a polynomial root wizard in the toolbox/cas/polynomial menu
8. Add Torque units
9. Add save/load of work in home
10. Add triangle surface calculation in triangle solver
11. Solve app: one can enter equations that use undefined variables. It will ask if and where they need to be created
12. Allow ifactor and similar function to be disabled in exam mode math/numbers
13. Cas median, quartile and mean functions are now disabled when Do1VStat is disabled in exam mode
14. Cas regressions fuctions are now disabled when Stat2Vars is disabled in exam mode
Cas change:
1. fix bisection solver
2. fix for derivative evaluation and for solve
3. fix for solve(22044=6000+264*((x+1)^(60)-1)/(x)*(1)/((x+1)^(60))+7000*(1)/((x+1)^(60)))
4. fix for solve([x*y^3=10^11,x^2/y=10^8],[x,y])
5. fix for solve(exp(x)=x+1)
6. fix for usimplify, e.g. usimplify(1_W*1_s)
7. fix matrix reduction/inverse for approx matrices with mixed real/complex entries
8. fix parsing of %%
9. fix potential overflow in ichinrem
10. gbasis memory alloc fixes
11. implicit declaration as global variables of variable names in optional assignation of arguments
12. improve factor(x^5-1) if sqrt is checked
13. improved precision for normald_cdf with negative arguments
14. improvement for integration of normald(x)*normald_cdf(x)
15. increase default number of steps for bisection solver
16. patch for limit(((sin(x))^(2))+((cos(x))^(2)),x=inf)
17. some list processing for polar/rectangular_coordinates
18. avoid infinite loop for desolve(y'=((-((y)^(3)))+((51)*((y)^(2))))-(((5/100))*(y)))
19. fix for piecewise conversion if one test is true or false
20. optionnal arguments left, right, center, tail for normald_icdf (also for Student, Fisher and Chi Square)
21. texpand improvement for texpand(tan(pi/2-x))
fixed bugs:
1. no more reset in spreadsheet if goto and no entry
2. Most Geometry app display should follow the Number Format
3. #FF:64 edition in base was incorrect...
4. (2_s)^-1 gave a wrong result!
5. ABS(1/3+1/3+1/3) was not 1
6. RPN sequences were not evaluated when executed in dialog boxes or spreadsheet
7. could not integrate between F1 and F2=dF1(X)/X=X
8. crash if trying to user assign ON+ combination
9. crash in user keys when switching views
10. create help program from the program editor yielded a crash upon escape from newly created program
11. drawing X^(2/3) did not show anything in negative
12. edit mat, in readonly mode, did not display correctly the user selected title.
13. entering a bad RPN command (like 1+2) in 2 var stat column caused a crash...
14. paste of a quoted " did not work
So, back to which one doesn't work on mines.
That contained (fixed bugs):
But I can definitely tell you, that if I type (and I use the little vertical line instead of ABS, yeah?)
ABS(1/3+1/3+1/3) and then hit Enter, then I get the result of 0.9999999999.
Was that not one of the fixes?
Point 5 should have sorted out for me:
But if I search the manual
10-05-2021, 10:35 PM
(10-05-2021 10:14 PM)matalog Wrote:  I'm a little bit confused by this software update.
The release notes have not been updated for this release.
In CAS I get 1 for abs(1/3+1/3+1/3)
In Home I get .9999999999
Tom L
Cui bono?
10-06-2021, 12:17 AM
(10-05-2021 10:35 PM)toml_12953 Wrote:  The release notes have not been updated for this release.
Eric posted some minor notes from CdB above; looks like a very small bug-fix release.
As for your results, they both look correct to me.
