Python: How do I save a graphic?
10-06-2021, 10:50 PM (This post was last modified: 10-06-2021 10:51 PM by Guenter Schink.)
In my App Mandelbrot Explorer I tried to save a picture in graphic G1 by:
name="tst.jpg"
hpprime.eval("MandelExpl.AFiles(name):=G1")
this line is executed without any error, but there is no graphic stored. When I terminate the App, I still can save this picture from the command line by AFiles(name):=G1. And then it shows up in the connectivity kit as a file at the right place.
Does someone have a clue?
Günter
10-06-2021, 11:01 PM
RE: Python: How do I save a graphic?
(10-06-2021 10:50 PM)Guenter Schink Wrote:  In my App Mandelbrot Explorer I tried to save a picture in graphic G1 by:
name="tst.jpg"
Günter
Have you tried:
name="tst.jpg"
hpprime.eval("MandelExpl.AFiles(" & name & "):=G1")
or
hpprime.eval("MandelExpl.AFiles(tst.jpg):=G1")
Tom L
Cui bono?
10-07-2021, 04:21 PM
If you are trying to put tst.jpg into G1, should it be:
hpprime.eval("G1:=MandelExpl.AFiles(name)")
-road
10-07-2021, 09:19 PM
Thanks for your inputs, but that didn't help
Anyway a little bit of progress.
When I end the Mandelbrot Explorer, and I am in "Python Numeric View" and I enter
from hppprime import *
eval('AFiles("test.png"):=G1')
then G1 is successfully stored in test.png. But when I exchange quotes and double quotes a Syntax Error is raised. So far so good, that's an easy one.
Next try:
aa="test.png"
eval('AFiles(aa):=G1')
Results in Syntax Error
Next try:
aa="test.png"
xx=eval('AFiles(aa):=G1')
No Error, but also no file: test.png
type(xx) gives <class 'str'>, but print(xx) gives Error:Syntax Error of course as you can't print a class. I think.
Next try: Function in the Mandelbrot Explorer
def save():
    eval('AFiles("test3.png"):=G1')
    line(0,0,240,320,0,0) #to show the function was executed
Tataa test3.png is there
Next try:
def save():
    aa="test3.png"
    eval('AFiles(aa):=G1')          #prefacing with xx=  doesn't change anything
No error, but also no file,
Hmm ....
Conclusion so far: providing a file name directly works but submitting a file name as a variable does not.
any suggestions?
Günter
10-07-2021, 10:25 PM
(10-07-2021 09:19 PM)Guenter Schink Wrote:  Thanks for your inputs, but that didn't help
Next try:
aa="test.png"
Next try:
aa="test.png"
def save():
Next try:
def save():
    aa="test3.png"
Hmm ....
any suggestions?
Günter
Did you try eval('AFiles(' + aa + '):=G1')
Tom L
Cui bono?
10-08-2021, 01:18 PM
... to the last proposal using the string concatenation, one might probably have to add double quotes in the leading and trailing strings to quote the content of variable aa ...
10-08-2021, 07:07 PM
Thank you Tom and Martin,
but that didn't work either. Whether with single quotes or double quotes in various combinations. I don't understand, how string concatenation is supposed to help at all?
I guess the problem is not in Python itself but in the implementation of the hpprime module, specifically "eval()". I.e. I wasn't able to have TEXTOUT deliver something through hpprime.eval().
Günter
